I have been working a lot with the Arduino platform over the last year. Arduino makes it very easy for beginners (in my opinion) to get started and has a large community and a lot of libraries for all kinds of peripherals.
Now, I am considering to have a look at mbed, too. What are the main differences I would face, both practical and conceptually?
Glorfindel
  • 578
fuenfundachtzig
  • 1,535
  • 26
As both an Mbed user and an Arduino user, this is my perspective on the differences between the platforms.
  1. The IDEs are completely different. The Mbed IDE is an in-browser compiler that allows you to easily import other people's source code. It is a full c/c++ IDE that saves your code to your online Mbed account. You must be signed in to do any development work (requires internet access). Code completion exists, but is clunky. Project format more closely mirrors c/c++ programming than does Arduino's environment.
  2. Programming the board is different. The Mbed uses a custom boot loader. The Mbed shows up as a flash drive when you plug it into your computer via USB. You compile your code using the online IDE, download the .hex file, and copy it to the Mbed. It's actually pretty neat, but more time consuming than clicking the 'Upload' button in the Arduino IDE.
  3. The Hardware is different. This means different pinouts, as well as different capabilities. Take a look at the Mbed platforms and compare them to the Arduinos. Mbeds are generally more powerful than Arduinos (cpu speed, mem size, build in capabilities).
I use my Mbed when my Arduino isn't powerful enough or fast enough. It would replace Arduinos for me if it wasn't for the online IDE. The IDE is a little awkward to use, and it takes too long to program the board (downloading/copying and pasting is much more inconvenient).
I'm able to use all my same sensors and peripherals that I purchased for the Arduino with my Mbed (Except for shields due to the physical layout differences). I sometimes have to rewrite code to get it to work on the Mbed, but that's a good learning exercise.
krol
  • 463
Mbed is so cool.The code is written everywhere that can get internet access. You doesn't like online IDE, you can get offline IDE such as Keil, GCC. You can get other kind of interface such as Matlab and LabView. Component and library is express together at main website. We can import lib: directly to workplace. If you have an idea, it is good to implement your idea quickly and best for prototyping. I also like Arduino but I like mbed than Arduino.
You can run mbed offline. I do my development in VSCode using the mbed-cli to compile and pyopenOCD for debugging. The instructions on the website didn't seem to work out of the box on Windows. Wasn't too difficult to set-up, though.
R001W
