The code below is a program that aims to apply the Pans-Thompskin algorithm to a signal attained from a ECG filter. The filter seems to work alright but it fails to blink the LED and collect a correct heart rate. The threshold might be the problem but I am struggling to see what is exactly correct.
#include <bluefruit.h>
int Threshold =160000; // The measurement of the pulse.
#define Threshold2 600 // The time of the pulse.
#define INTERVAL 10 // Used for 25 millisecond timer.
//intiation for heart rate
unsigned long Timer;
unsigned long Timer2;// Declares two timers.
enum Heart { Wait, Idle, Update};
enum Heart HeartState;// Used for states in the state machine below.
float HBI;
float SixHBI = 0.0;
float HBIAverage = 0.0;
float BPM = 0.0;
int Count = 0;
float filtered = 0;
//dg filter initailization
float xn1 = 0; //declare xn1 as zero
float yn1 = 0;
int k = 0;
//moving average
const int numReadings = 30;
int readings [numReadings];
int readIndex = 0;
long total = 0;
long average;
void HbiStd(float Value) {
switch (HeartState) {
case Wait:
if (millis() - Timer2 > Threshold2) {
HeartState = Idle;
// If 600 milliseconds pass, go to Idle state.
break;
case Idle:
if (Value > Threshold) {
HeartState = Update;
// If Heartbeat is detected go into Update state.
break;
case Update:
HBI = millis() - Timer2; // Stores HBI time.
Timer2 += HBI; // Increments Timer2.
SixHBI += HBI; // Adds all HBI together.
HBIAverage = SixHBI / 6000; // Calculates average HBI.
BPM = (1 / HBIAverage) * (60); // Calculates BPM.
Count++; // Increments what pass it is on.
if (Count == 6) { // State machine goes through 6 times.
// Serial.print(String(BPM) + String(" BPM\n"));
// Prints the BPM.
SixHBI = 0;
Count = 0;
// Resets the HBI and counter.
HeartState = Wait; // Go back to wait state.
break;
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
analogReadResolution(12);
Serial.begin(115200);
Timer = millis(); // Timer setup.
Timer2 = millis(); // Initiate Timer2.
HeartState = Wait; // State machine starts in wait state.
uint8_t INPUT_PIN = A1;
//varible for moving average filter
if (millis() - Timer >= INTERVAL)
{ float raw = analogRead(INPUT_PIN);//read in data from input;
filtered = Pan_thom_alg(raw);
if (k % 3 == 0)
//int filtered = raw*raw;//square
// Serial.print(String(raw) + String(" raw\n"));
Serial.print(String(filtered) + String(" filtered\n"));
if (filtered > Threshold) {
digitalWrite(LED_BUILTIN, HIGH);
delay(50);
if (filtered < Threshold) {
//delay(10);
k = k + 1;
Timer += INTERVAL;
HbiStd(filtered); // State machine is called and always runs.
//delay(10);
//print after 3 entries are recorded for notch
float Pan_thom_alg(float raw) {
float xn = raw;
filtered = -0.00084 * yn1 + 0.999 * xn + -0.0008 * xn1;
xn1 = xn;
yn1 = filtered;
//square data
filtered = sq(filtered);
// subtract the last reading:
total = total - readings[readIndex];
// read the sensor:
readings[readIndex] = filtered;
// add value to total:
total = total + readings[readIndex];
// handle index
readIndex = readIndex + 1;
if (readIndex >= numReadings) {
readIndex = 0;
// calculate the average:
average = total / numReadings;
filtered = average;
return filtered;
