I have coded a robot to be controlled by a ps3 Controller. I am using continous rotation servos but unfortunately I can not figure out how to get them to change direction. My input for my if statements is correct, but for some reason even if the input from the PS3 controller shows to do the reverse direction, the continuous rotation servo still rotates forward.
Here is my Code:
#include <PS3BT.h>
#include <usbhub.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
#include <Servo.h>
USB Usb;
//USBHub Hub1(&Usb); // Some dongles have a hub inside
BTD Btd(&Usb); // You have to create the Bluetooth Dongle instance like so
/* You can create the instance of the class in two ways */
PS3BT PS3(&Btd); // This will just create the instance
//PS3BT PS3(&Btd, 0x00, 0x15, 0x83, 0x3D, 0x0A, 0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
bool printTemperature, printAngle;
// identifying servos
Servo LeftServo;
Servo RightServo;
Serial.begin(115200);
#if !defined(MIPSEL)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while (1); //halt
Serial.print(F("\r\nPS3 Bluetooth Library Started"));
// Attaching Pins to Servos
LeftServo.attach(2);
RightServo.attach(3);
Usb.Task();
if (PS3.PS3Connected || PS3.PS3NavigationConnected) {
if (PS3.getAnalogHat(LeftHatY) < 117){
Serial.print(F("\tLeftHatY: "));
Serial.print(PS3.getAnalogHat(LeftHatY));
LeftServo.write(180);
else if (PS3.getAnalogHat(LeftHatY) > 140) {
LeftServo.write(0);
else {
LeftServo.detach();
