I have problem to store values to MySQL table from Arduino MKR 1010 Wifi. I get the following message.
trying
got: 0 retrying
trying
got: 0 retrying
ERROR!
I have also tried to turn off firewall without success. Is my code wrong? Can someone help me with this issue?
#include <Ethernet.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#include <MySQL_Encrypt_Sha1.h>
#include <MySQL_Packet.h>
#include <DHT.h>
#include <DHT_U.h>
#include <dht.h>
#include <WiFiNINA.h>
#include <wifiinfo.h>
byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
#define DHT22_PIN 7
#define DHTTYPE 22
DHT deviceMonitor(DHT22_PIN,DHTTYPE) ;
IPAddress server_addr(192,168,86,39); // IP of the MySQL server here
char user[] = "root"; // MySQL user login username
char password2[] = "test1234"; // MySQL user login password
char ssid[] = SECRET_SSID; // your network SSID (name)
char password[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the Wifi radio's status
float hum;
float temp;
float humError;
float tempError;
int checkTemp;
char INSERT_DATA[] = "INSERT INTO weather (temp, hum) VALUES ('%s','%d')";
char query[128];
char temperature[10];
EthernetClient client;
MySQL_Connection conn((Client *)&client);
//Initialize serial and wait for port to open:
Serial.begin(9600);
while (!Serial); // wait for serial port to connect
Ethernet.begin(mac_addr);
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to network: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, password);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.println("You're connected to the network");
Serial.println("----------------------------------------");
printData();
if (conn.connect(server_addr, 3306, user, password))
delay(1000);
else
Serial.println("Mysql connection failed.");
void loop()
delay(5000);
if (conn.connect(server_addr, 3306, user, password2)) {
MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
checkTemp = deviceMonitor.read(DHT22_PIN);
hum = deviceMonitor.readHumidity();
temp = deviceMonitor.readTemperature();
Serial.println((String)"Temperature: " + temp + " Celsius");
Serial.println((String)"Humidity: " + hum +"%");
Serial.println();
sprintf(query, INSERT_DATA, temp, hum);
cur_mem->execute(query);
delete cur_mem;
Serial.println("Data recorded.");
delay(10000);
else
Serial.println("ERROR!");
void printData()
Serial.println("Board Information:");
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
Serial.println();
Serial.println("Network Information:");
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption, HEX);
Serial.println();
