I have dual boot laptop, Windows 11 & Linux Mint 21 (default boot). when running Arduino IDE 1.8.19 using Linux the port not accessible [from tools/port], but if I boot as windows, I can access the port from the Arduino IDE.
Other applications running in Linux can access the USB drive without issue (eg FreeCAD, PrusaSlicer). Arduino IDE is the only app so far with this USB issue.
"dialout" is in my list of groups
Arduino IDE was installed using apt
If I run lsusb when the nano is connected, i see the following extra entry
Bus 003 Device 009: ID 1a86:7523 QinHeng Electronics CH340 serial converter
On another post it suggested running ls -l /dev/ttyUSB* and ls -l /dev/ttyACM*. For both I get the response "No such file or directory". The following files starting with tty* are in the /dev directory
tty tty11 tty15 tty19 tty22 tty26 tty3 tty33 tty37 tty40 tty44 tty48 tty51 tty55 tty59 tty62 tty9 ttyS10 ttyS14 ttyS18 ttyS21 ttyS25 ttyS29 ttyS4 ttyS8
tty0 tty12 tty16 tty2 tty23 tty27 tty30 tty34 tty38 tty41 tty45 tty49 tty52 tty56 tty6 tty63 ttyprintk ttyS11 ttyS15 ttyS19 ttyS22 ttyS26 ttyS3 ttyS5 ttyS9
tty1 tty13 tty17 tty20 tty24 tty28 tty31 tty35 tty39 tty42 tty46 tty5 tty53 tty57 tty60 tty7 ttyS0 ttyS12 ttyS16 ttyS2 ttyS23 ttyS27 ttyS30 ttyS6
tty10 tty14 tty18 tty21 tty25 tty29 tty32 tty36 tty4 tty43 tty47 tty50 tty54 tty58 tty61 tty8 ttyS1 ttyS13 ttyS17 ttyS20 ttyS24 ttyS28 ttyS31 ttyS7
If I tail the system log and plug the nano into the usb drive I get the following (the answer my be here but I cant see it).
Oct 7 17:17:14 HP-Envyl kernel: [ 8949.381626] usb 3-4: new full-speed USB device number 14 using xhci_hcd
Oct 7 17:17:14 HP-Envyl kernel: [ 8949.599105] usb 3-4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
Oct 7 17:17:14 HP-Envyl kernel: [ 8949.599107] usb 3-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Oct 7 17:17:14 HP-Envyl kernel: [ 8949.599108] usb 3-4: Product: USB Serial
Oct 7 17:17:14 HP-Envyl kernel: [ 8949.601365] ch341 3-4:1.0: ch341-uart converter detected
Oct 7 17:17:14 HP-Envyl mtp-probe: checking bus 3, device 14: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"
Oct 7 17:17:14 HP-Envyl mtp-probe: bus: 3, device: 14 was not an MTP device
Oct 7 17:17:14 HP-Envyl kernel: [ 8949.601888] usb 3-4: ch341-uart converter now attached to ttyUSB0
Oct 7 17:17:14 HP-Envyl systemd[1]: Starting Braille Device Support...
Oct 7 17:17:14 HP-Envyl brltty[12613]: BRLTTY 6.4 rev BRLTTY-6.4 [https://brltty.app/]
Oct 7 17:17:14 HP-Envyl brltty[12613]: executing as the invoking user: root
Oct 7 17:17:14 HP-Envyl brltty[12613]: brltty: executing as the invoking user: root
Oct 7 17:17:14 HP-Envyl brltty[12613]: CLDR open error: No such file or directory: /usr/share/unicode/cldr/common/annotations/en.xml
Oct 7 17:17:14 HP-Envyl brltty[12613]: brltty: CLDR open error: No such file or directory: /usr/share/unicode/cldr/common/annotations/en.xml
Oct 7 17:17:14 HP-Envyl brltty[12613]: brltty: possible cause: the package that defines the CLDR annotations directory is not installed
Oct 7 17:17:14 HP-Envyl brltty[12613]: brltty: emoji substitutiion won't be performed
Oct 7 17:17:14 HP-Envyl brltty[12613]: brltty: BrlAPI Server: release 0.8.3
Oct 7 17:17:14 HP-Envyl brltty[12613]: possible cause: the package that defines the CLDR annotations directory is not installed
Oct 7 17:17:14 HP-Envyl systemd[1]: Started Braille Device Support.
Oct 7 17:17:14 HP-Envyl brltty[12613]: emoji substitutiion won't be performed
Oct 7 17:17:14 HP-Envyl brltty[12613]: BrlAPI Server: release 0.8.3
Oct 7 17:17:14 HP-Envyl brltty[12613]: Linux Screen Driver:
Oct 7 17:17:14 HP-Envyl brltty[12613]: brltty: Linux Screen Driver:
Oct 7 17:17:14 HP-Envyl kernel: [ 8950.123164] input: BRLTTY 6.4 Linux Screen Driver Keyboard as /devices/virtual/input/input49
Oct 7 17:17:15 HP-Envyl brltty[12613]: USB configuration set error 16: Device or resource busy
Oct 7 17:17:15 HP-Envyl brltty[12613]: brltty: USB configuration set error 16: Device or resource busy
Oct 7 17:17:15 HP-Envyl brltty[12613]: USB interface in use: 0 (ch341)
Oct 7 17:17:15 HP-Envyl brltty[12613]: brltty: USB interface in use: 0 (ch341)
Oct 7 17:17:15 HP-Envyl ModemManager[1013]: <info> [base-manager] port ttyUSB0 released by device '/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4'
Oct 7 17:17:15 HP-Envyl ModemManager[1013]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4': Operation was cancelled
Oct 7 17:17:15 HP-Envyl kernel: [ 8950.239032] usb 3-4: usbfs: interface 0 claimed by ch341 while 'brltty' sets config #1
Oct 7 17:17:15 HP-Envyl kernel: [ 8950.239683] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
Oct 7 17:17:15 HP-Envyl kernel: [ 8950.239693] ch341 3-4:1.0: device disconnected
Oct 7 17:17:15 HP-Envyl brltty[12613]: NoSpeech Speech Driver:
Oct 7 17:17:15 HP-Envyl brltty[12613]: brltty: NoSpeech Speech Driver:
Oct 7 17:17:18 HP-Envyl rtkit-daemon[3252]: Supervising 10 threads of 3 processes of 1 users.
Does anyone have any idea what can cause this issue?
