I want to make a 10 channels Arduino mega-based battery capacity tester using 4.7 ohms 10w resistors controlling them with IRFZ44n MOSFETs with respected digital pins. An 8.4V battery powers the Arduino (do not consider the buck converter in the picture). I am debugging my project step by step. When I read voltages of individual batteries by corresponding analog pins without turning On 'MOSFET-Gate pins' then Arduino measures the voltages correctly but when I turn on the gate pins then Arduino measures voltage incorrectly. Meaning if I connect a battery with an analog pin and a multimeter at the same time and the value is pretty much same. Like 3.70 volt for the multimeter and 3.72 for analog pin but when I turn On the gatepin of the MOSFET then Arduino value is like 3.07V and Multimeter value is 3.48V. Thanks in advance.
Here is the Circuit Diagram of my project: enter image description here
Simple version to understand: enter image description here
Code:
long readVcc() {
   // Read 1.1V reference against AVcc
   // set the reference to Vcc and the measurement to the internal 1.1V reference
#if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
   ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
   ADMUX = _BV(MUX5) | _BV(MUX0) ;
#else
   ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#endif
   ADCSRB &= ~_BV(MUX5);
   delay(2); // Wait for Vref to settle
   ADCSRA |= _BV(ADSC); // Start conversion
   while (bit_is_set(ADCSRA,ADSC)); // measuring
uint8_t low = ADCL; // must read ADCL first - it then locks ADCH uint8_t high = ADCH; // unlocks both
long result = (high<<8) | low;
result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.110231000 //1126400L internalRefVolt(1.1) * 1023 * 1000; code can more precse by calculating internalRefVolt(1.1) return result; // Vcc in millivolts }
void setup() { Serial.begin(115200); delay(3000); pinMode(22,OUTPUT);//*Mosfet Gate Pins****** pinMode(23,OUTPUT); pinMode(24,OUTPUT); pinMode(25,OUTPUT); pinMode(26,OUTPUT); pinMode(27,OUTPUT); pinMode(28,OUTPUT); pinMode(29,OUTPUT); pinMode(30,OUTPUT); pinMode(31,OUTPUT);
digitalWrite(22,LOW);//*Initially low the Mosfet Gate Pins****** digitalWrite(23,LOW); digitalWrite(24,LOW); digitalWrite(25,LOW); digitalWrite(26,LOW); digitalWrite(27,LOW); digitalWrite(28,LOW); digitalWrite(29,LOW); digitalWrite(30,LOW); digitalWrite(31,LOW); }
/********************************Void Loop****************************************************/ void loop() { float voltRef = readVcc() / 1000.0;
digitalWrite(22,HIGH);//*** High the Mosfet Gate Pins******** digitalWrite(23,HIGH); digitalWrite(24,HIGH); digitalWrite(25,HIGH); digitalWrite(26,HIGH); digitalWrite(27,HIGH); digitalWrite(28,HIGH); digitalWrite(29,HIGH); digitalWrite(30,HIGH); digitalWrite(31,HIGH);
float volt0 = analogRead(A0)(voltRef/1024); delay(10); volt0 = analogRead(A0)(voltRef/1024); /* if(volt0>3.0){ digitalWrite(22,HIGH); // High = Mosfet ON digitalWrite(36,HIGH); // High = LED Turn OFF
float volt1 = analogRead(A1)(voltRef/1024); delay(10); volt1 = analogRead(A1)(voltRef/1024);
float volt2 = analogRead(A2)(voltRef/1024); delay(10); volt2 = analogRead(A2)(voltRef/1024);
float volt3 = analogRead(A3)(voltRef/1024); delay(10); volt3 = analogRead(A3)(voltRef/1024);
float volt4 = analogRead(A4)(voltRef/1024); delay(10); volt4 = analogRead(A4)(voltRef/1024);
float volt5 = analogRead(A5)(voltRef/1024); delay(10); volt5 = analogRead(A5)(voltRef/1024);
float volt6 = analogRead(A6)(voltRef/1024); delay(10); volt6 = analogRead(A6)(voltRef/1024);
float volt7 = analogRead(A7)(voltRef/1024); delay(10); volt7 = analogRead(A7)(voltRef/1024);
float volt8 = analogRead(A8)(voltRef/1024); delay(10); volt8 = analogRead(A8)(voltRef/1024);
float volt9 = analogRead(A9)(4.95/1024); delay(10); volt9 = analogRead(A9)(4.95/1024);
//***************************************************************************** Serial.print("B0= "); Serial.println(volt0);
Serial.print("B1= "); Serial.println(volt1);
Serial.print("B2= "); Serial.println(volt2);
Serial.print("B3= "); Serial.println(volt3);
Serial.print("B4= "); Serial.println(volt4);
Serial.print("B5= "); Serial.println(volt5);
Serial.print("B6= "); Serial.println(volt6);
Serial.print("B7= "); Serial.println(volt7);
Serial.print("B8= "); Serial.println(volt8);
Serial.print("B9= "); Serial.println(volt9);
Serial.println(""); Serial.println("=========================="); delay(500); }
Edgar Bonet
  • 45,094
  • 81
Electric wires have resistance. Most of the time this resistance can be ignored, but this is not always the case. Specifically, if the wire is carrying a large amount of current, the voltage drop across it can be significant.
Consider this circuit:
schematic
The red wires carry a high current, and experience a significant voltage drop. Wires in black carry almost no current, and are equi-potential. Both voltmeters on the left will measure the same voltage, which is affected by the voltage drops along AB and along DE. The voltmeter on the right measures a lower voltage, because it is also affected by the drops along BC and EF.
In your experiment the problem is compounded by the fact that the ground wire is carrying the current from all the batteries. It is therefore responsible of most of the voltage drop you experience.
The takeaway is that you have to make sure the junction points between the current carrying wires and the measurement wires (points B and E for the voltmeters on the left) are as close as possible to the battery. Otherwise your measurement will be biased.
Edgar Bonet
  • 45,094
  • 81
The main problem was the battery holder default wire, those wires were have high resistance. After changing those wire the problem was solved. Thank you everyone
