I'm using an ESP8266 for IOT devices.
I wish to work with an ESP32 and harvest its benefits - for my uses managing WiFi and MQTT connectivity.
Most tasks examples are very basic and quite the same (blinking LEDs). But for a real time application, more data is needed for which I can't find a guide.
For example:
- when to use
core0orcore1? - How to evaluate stack size needed for a task?
- Are there any limitation for a task? Is a
mqtt.loop()for example, ligit, memory wise?
I'd be happy to read about real life-implementations for tasks (especially "dos" and "don'ts")
Example usage from ESP32 DOCS
// Dimensions the buffer that the task being created will use as its stack.
// NOTE: This is the number of bytes the stack will hold, not the number of
// words as found in vanilla FreeRTOS.
#define STACK_SIZE 200
// Structure that will hold the TCB of the task being created.
StaticTask_t xTaskBuffer;
// Buffer that the task being created will use as its stack. Note this is
// an array of StackType_t variables. The size of StackType_t is dependent on
// the RTOS port.
StackType_t xStack[ STACK_SIZE ];
// Function that implements the task being created.
void vTaskCode( void * pvParameters )
// The parameter value is expected to be 1 as 1 is passed in the
// pvParameters value in the call to xTaskCreateStatic().
configASSERT( ( uint32_t ) pvParameters == 1UL );
for( ;; )
// Task code goes here.
// Function that creates a task.
void vOtherFunction( void )
TaskHandle_t xHandle = NULL;
// Create the task without using any dynamic memory allocation.
xHandle = xTaskCreateStatic(
vTaskCode, // Function that implements the task.
"NAME", // Text name for the task.
STACK_SIZE, // Stack size in bytes, not words.
( void * ) 1, // Parameter passed into the task.
tskIDLE_PRIORITY,// Priority at which the task is created.
xStack, // Array to use as the task's stack.
&xTaskBuffer ); // Variable to hold the task's data structure.
// puxStackBuffer and pxTaskBuffer were not NULL, so the task will have
// been created, and xHandle will be the task's handle. Use the handle
// to suspend the task.
vTaskSuspend( xHandle );
