I'm working on nRF52832 Bluefruit Adafruit Module. I want the BLE connection to disconnect using a function and can call whenever required. But the issue is the disconnect function needs "conn_handle" to disconnect from the current connected Client.
Can anyone help me find where I can get the "conn_handle" of the connected client?
 * Callback invoked when a connection is dropped
 * @param conn_handle
 * @param reason is a BLE_HCI_STATUS_CODE which can be found in ble_hci.h
void disconnect_callback(uint16_t conn_handle, uint8_t reason)
  (void) conn_handle;
  (void) reason;
connection_num--;
// Mark the ID as invalid int id = findConnHandle(conn_handle);
// Non-existant connection, something went wrong, DBG !!! if ( id < 0 ) return;
// Mark conn handle as invalid prphs[id].conn_handle = BLE_CONN_HANDLE_INVALID;
Serial.print(prphs[id].name); Serial.println(" disconnected!"); }
The below complete code is for "Central Bleuart Multi"-
This is an example for our nRF52 based Bluefruit LE modules
Pick one up today in the adafruit shop!
Adafruit invests time and resources providing this open source code, please support Adafruit and open-source hardware by purchasing products from Adafruit!
MIT license, check LICENSE for more information All text above, and the splash screen below must be included in any redistribution *********************************************************************/
/* This sketch demonstrates the central API() that allows you to connect
  • to multiple peripherals boards (Bluefruit nRF52 in peripheral mode, or
  • any Bluefruit nRF51 boards).
  • One or more Bluefruit boards, configured as a peripheral with the
  • bleuart service running are required for this demo.
  • This sketch will:
    • Read data from the HW serial port (normally USB serial, accessible
  • via the Serial Monitor for example), and send any incoming data to
  • all other peripherals connected to the central device.
    • Forward any incoming bleuart messages from a peripheral to all of
  • the other connected devices.
  • It is recommended to give each peripheral board a distinct name in order
  • to more easily distinguish the individual devices.
  • Connection Handle Explanation
  • The total number of connections is BLE_MAX_CONNECTION (20)
  • The 'connection handle' is an integer number assigned by the SoftDevice
  • (Nordic's proprietary BLE stack). Each connection will receive it's own
  • numeric 'handle' starting from 0 to BLE_MAX_CONNECTION-1, depending on the order
  • of connection(s).
    • E.g If our Central board connects to a mobile phone first (running as a peripheral),
  • then afterwards connects to another Bluefruit board running in peripheral mode, then
  • the connection handle of mobile phone is 0, and the handle for the Bluefruit
  • board is 1, and so on.
/* LED PATTERNS
  • LED_RED - Blinks pattern changes based on the number of connections.
  • LED_BLUE - Blinks constantly when scanning
#include <bluefruit.h>
// Struct containing peripheral info typedef struct { char name[16+1];
uint16_t conn_handle;
// Each prph need its own bleuart client service BLEClientUart bleuart; } prph_info_t;
/* Peripheral info array (one per peripheral device)
  • There are 'BLE_MAX_CONNECTION' central connections, but the
  • the connection handle can be numerically larger (for example if
  • the peripheral role is also used, such as connecting to a mobile
  • device). As such, we need to convert connection handles <-> the array
  • index where appropriate to prevent out of array accesses.
  • Note: One can simply declares the array with BLE_MAX_CONNECTION and use connection
  • handle as index directly with the expense of SRAM.
*/ prph_info_t prphs[BLE_MAX_CONNECTION];
// Software Timer for blinking the RED LED SoftwareTimer blinkTimer; uint8_t connection_num = 0; // for blink pattern
void setup() { Serial.begin(115200); while ( !Serial ) delay(10); // for nrf52840 with native usb
// Initialize blinkTimer for 100 ms and start it blinkTimer.begin(100, blink_timer_callback); blinkTimer.start();
Serial.println("Bluefruit52 Central Multi BLEUART Example"); Serial.println("-----------------------------------------\n");
// Initialize Bluefruit with max concurrent connections as Peripheral = 0, Central = 4 // SRAM usage required by SoftDevice will increase with number of connections Bluefruit.begin(0, 4);
// Set Name Bluefruit.setName("Bluefruit52 Central");
// Init peripheral pool for (uint8_t idx=0; idx<BLE_MAX_CONNECTION; idx++) { // Invalid all connection handle prphs[idx].conn_handle = BLE_CONN_HANDLE_INVALID;
// All of BLE Central Uart Serivce
prphs[idx].bleuart.begin();
prphs[idx].bleuart.setRxCallback(bleuart_rx_callback);
// Callbacks for Central Bluefruit.Central.setConnectCallback(connect_callback); Bluefruit.Central.setDisconnectCallback(disconnect_callback);
/* Start Central Scanning
    • Enable auto scan if disconnected
    • Interval = 100 ms, window = 80 ms
    • Filter only accept bleuart service in advertising
    • Don't use active scan (used to retrieve the optional scan response adv packet)
    • Start(0) = will scan forever since no timeout is given
*/ Bluefruit.Scanner.setRxCallback(scan_callback); Bluefruit.Scanner.restartOnDisconnect(true); Bluefruit.Scanner.setInterval(160, 80); // in units of 0.625 ms Bluefruit.Scanner.filterUuid(BLEUART_UUID_SERVICE); Bluefruit.Scanner.useActiveScan(false); // Don't request scan response data Bluefruit.Scanner.start(0); // 0 = Don't stop scanning after n seconds }
  • Callback invoked when scanner picks up an advertising packet
  • @param report Structural advertising data
/ void scan_callback(ble_gap_evt_adv_report_t report) { // Since we configure the scanner with filterUuid() // Scan callback only invoked for device with bleuart service advertised
// Connect to the device with bleuart service in advertising packet Bluefruit.Central.connect(report); }
  • Callback invoked when an connection is established
  • @param conn_handle
*/ void connect_callback(uint16_t conn_handle) { // Find an available ID to use int id = findConnHandle(BLE_CONN_HANDLE_INVALID);
// Eeek: Exceeded the number of connections !!! if ( id < 0 ) return;
prph_info_t* peer = &prphs[id]; peer->conn_handle = conn_handle;
Bluefruit.Connection(conn_handle)->getPeerName(peer->name, sizeof(peer->name)-1);
Serial.print("Connected to "); Serial.println(peer->name);
Serial.print("Discovering BLE UART service ... ");
if ( peer->bleuart.discover(conn_handle) ) { Serial.println("Found it"); Serial.println("Enabling TXD characteristic's CCCD notify bit"); peer->bleuart.enableTXD();
Serial.println(&quot;Continue scanning for more peripherals&quot;);
Serial.println(&quot;Enter some text in the Serial Monitor to send it to all connected peripherals:&quot;);
} else { Serial.println("Found ... NOTHING!");
// disconnect since we couldn't find bleuart service
Bluefruit.disconnect(conn_handle);
connection_num++; }
  • Callback invoked when a connection is dropped
  • @param reason is a BLE_HCI_STATUS_CODE which can be found in ble_hci.h
*/ void disconnect_callback(uint16_t conn_handle, uint8_t reason) { (void) conn_handle; (void) reason;
connection_num--;
  • Callback invoked when BLE UART data is received
  • @param uart_svc Reference object to the service where the data
  • arrived.
*/ void bleuart_rx_callback(BLEClientUart& uart_svc) { // uart_svc is prphs[conn_handle].bleuart uint16_t conn_handle = uart_svc.connHandle();
int id = findConnHandle(conn_handle); prph_info_t* peer = &prphs[id];
// Print sender's name Serial.printf("[From %s]: ", peer->name);
// Read then forward to all peripherals while ( uart_svc.available() ) { // default MTU with an extra byte for string terminator char buf[20+1] = { 0 };
if ( uart_svc.read(buf,sizeof(buf)-1) )
  Serial.println(buf);
  sendAll(buf);
  • Helper function to send a string to all connected peripherals
/ void sendAll(const char str) { Serial.print("[Send to All]: "); Serial.println(str);
for(uint8_t id=0; id < BLE_MAX_CONNECTION; id++) { prph_info_t* peer = &prphs[id];
if ( peer-&gt;bleuart.discovered() )
  peer-&gt;bleuart.print(str);
void loop() { // First check if we are connected to any peripherals if ( Bluefruit.Central.connected() ) { // default MTU with an extra byte for string terminator char buf[20+1] = { 0 };
// Read from HW Serial (normally USB Serial) and send to all peripherals
if ( Serial.readBytes(buf, sizeof(buf)-1) )
  sendAll(buf);
  • Find the connection handle in the peripheral array
  • @param conn_handle Connection handle
  • @return array index if found, otherwise -1
*/ int findConnHandle(uint16_t conn_handle) { for(int id=0; id<BLE_MAX_CONNECTION; id++) { if (conn_handle == prphs[id].conn_handle) { return id; } }
return -1;
  • Software Timer callback is invoked via a built-in FreeRTOS thread with
  • minimal stack size. Therefore it should be as simple as possible. If
  • a periodically heavy task is needed, please use Scheduler.startLoop() to
  • create a dedicated task for it.
  • More information http://www.freertos.org/RTOS-software-timer.html
*/ void blink_timer_callback(TimerHandle_t xTimerID) { (void) xTimerID;
// Period of sequence is 10 times (1 second). // RED LED will toggle first 2*n times (on/off) and remain off for the rest of period // Where n = number of connection static uint8_t count = 0;
if ( count < 2*connection_num ) digitalToggle(LED_RED); if ( count % 2 && digitalRead(LED_RED)) digitalWrite(LED_RED, LOW); // issue #98
count++; if (count >= 10) count = 0; }
GitHub Source code
I want to invoke this disconnect function, but I don't know where to get conn_handle. If anyone has any idea please help me.
I have already tried going into libraries; the best it shows is just the definition of the callback function:
1: Bluefruit.Central.setDisconnectCallback(disconnect_callback);
2: void BLECentral::setDisconnectCallback( ble_disconnect_callback_t fp ) { _disconnect_cb = fp; }
3: class BLECentral { ... private: ble_disconnect_callback_t _disconnect_cb; }
4: typedef void (*ble_disconnect_callback_t ) (uint16_t conn_hdl, uint8_t reason);
This is all I got regarding this disconnect function in different libraries following the definition but nothing related to conn_handle.
Idk if its a right or not but it works.
When there's is a new connection established, "connect" gets revoked, with "conn_handle" as its argument. If someone knows please tell how is this function revoke itself.
But what I did is make a global variable uint16_t conn_handle
uint16_t g_conn_handle;
      g_conn_handle=conn_handle;
  // Eeek: Exc
Now I can call the Disconnect function with this g_conn_handle global variable.
