I want to reboot relay (turn off , waiting 4 seconds and turn ON) it works perfectly if I use delay(4000), but code is blocked while delay (4 seconds) and I cant start relay 2. How can I use Millis instead of delay to reboot relay 1 and start relay 2 same time?
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include <EthernetUdp.h> //Load the Udp Library
//Ethernet
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; //Assign mac address
IPAddress ip(192, 168, 1, 178); //Assign the IP Adress
unsigned int localPort = 80; // Assign a port to talk over
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //dimensian a char array to hold our data packet
String datReq; //String for our data
int packetSize; //Size of the packet
EthernetUDP Udp; // Create a UDP Object //server port
String readString;
bool relayState = false;
//define relay pins
int relay_1 = 22;
int relay_2 = 24;
Serial.begin(9600);
Ethernet.begin(mac, ip);
Udp.begin(localPort); //Initialize Udp
delay(2000);
//Initial state of the relay
pinMode(relay_1, OUTPUT); digitalWrite(relay_1, LOW); //relay 1 is On
pinMode(relay_2, OUTPUT); digitalWrite(relay_2, HIGH);//relay 2 is Off
packetSize = Udp.parsePacket(); //Reads the packet size
if (packetSize > 0) { //if packetSize is >0, that means someone has sent a request
Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE); //Read the data request
String datReq(packetBuffer); //Convert char array packetBuffer into a string called datReq
//Serial.println(datReq);
if (datReq == "relay1reboot") { //reboot relay
digitalWrite(relay_1, HIGH);//relay off
delay(4000);
digitalWrite(relay_1, LOW);//relay on
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort()); //Initialize packet send
Udp.print("relay 1 reboot");
Udp.endPacket(); //End the packet
if (datReq == "relay2on") {
digitalWrite(relay_2, LOW);//relay 2 on
Udp.print("relay 2 on");
if (datReq == "relay1on") {
digitalWrite(relay_1, LOW);//relay 2 on
Udp.print("relay 1 on");
// Use the snapshot to set track time until next event
//previousMillis = currentMillis;
memset(packetBuffer, 0, UDP_TX_PACKET_MAX_SIZE); //clear out the packetBuffer array
