When I run this code, my pin and pinCheck arrays are not being filled with the results of keypad.getKey(). If I print the value at each index, the result is blank. As far as I can tell, I am either not writing a char to the array, I am misreading the array when it comes time to print to the serial monitor, or .getKey() only works in the main or loop functions.
#include <Key.h>
#include <Keypad.h>
void armDisarm(void); boolean array_cmp(char, char, int, int);
bool isArmed = 0; char pin[3]; char pinCheck[3]; const byte ROWS = 4; // number of rows const byte COLS = 4; // number of columns char keys[ROWS][COLS] = { {'1','2','3','A'}, {'4','5','6','B'}, {'7','8','9','C'}, {'#','0','*','D'} };
byte rowPins[ROWS] = {9, 8, 7, 6}; // row pinouts of the keypad R1 = D8, R2 = D7, R3 = D6, R4 = D5 byte colPins[COLS] = {5, 4, 3, 2}; // column pinouts of the keypad C1 = D4, C2 = D3, C3 = D2 Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
void setup() { Serial.begin(9600); }
void loop() { if (isArmed == 1) { Serial.println("SYSTEM ARMED! ENTER PIN TO DISARM!"); } else { Serial.println("SYSTEM DISARMED! ENTER PIN TO ARM!"); } armDisarm(); }
void armDisarm(void) { while(true) { if (isArmed == 0) { for (int i = 0; i < 4;) { if (keypad.getKey() == NO_KEY) { continue; } pin[i] = keypad.getKey(); Serial.println(pin[i]); i++; } isArmed = 1; return; } else if (isArmed == 1) { for (int j = 0; j < 4;) { if (keypad.getKey() == NO_KEY) { continue; } pinCheck[j] = keypad.getKey(); Serial.println(pin[j]); j++; } for (int k = 0; k < 4; k++) { if(pinCheck[k] != pin[k]) { isSame = 0; break; } else { isSame = 1; } }
  if (array_cmp(pin, pinCheck, sizeof(pin), sizeof(pinCheck)) == 1)
    Serial.println(&quot;same pin&quot;); //used for bebugging
    isArmed = 0;
    return;
  else
    Serial.println(&quot;INCORRECT PIN! CLAYMORE ROOMBA DEPLOYED!&quot;);
boolean array_cmp(char a[sizeof(pin)], char b[sizeof(pinCheck)], int len_a, int len_b) { int n;
// if their lengths are different, return false if (len_a != len_b) { return false; }
// test each element to be the same. if not, return false for (n = 0 ;n < len_a; n++) { if (a[n]!= b[n]) { return false; } }
//ok, if we have not returned yet, they are equal :) return true; }
ocrdu
  • 1,795
Ryan
First of all, there is one essential feature of the Keypad library you have to understand: it is non-blocking. When you call keypad.getKey(), it returns immediately, and almost always returns NO_KEY to signal that no key was pressed since the last time you checked. If a key was pressed, keypad.getKey() returns that key and then, on the next call, it again returns NO_KEY because no key was pressed since the last time you checked.
It is important to realize that, whenever a key is pressed, that key is returned only once by keypad.getKey(). You should manage to not miss it!
Now consider this loop:
        continue;
    i++;
This will run very fast, and almost always looping through the continue statement. When a key is pressed, keypad.getKey() returns a value different from NO_KEY (and this value is lost), the test within the if is false, and the statement that follows gets executed, namely:
But this is another call to keypad.getKey(), which returns NO_KEY, so this is what gets saved in the array.
This is how I would write that loop:
for (int i = 0; i < 3; i++)
    char key = NO_KEY;
    while (key == NO_KEY)
        key = keypad.getKey();
    pin[i] = key;
Please note that:
  • The value returned by keypad.getKey() is always saved into a variable, you do not want to loose it! When we get something other than NO_KEY, the value previously saved into the variable is stored in the array.
  • I moved the i++ where it belongs, in order to avoid that very confusing way of controlling the loop.
  • The if has become a while, because we do not want to move to the next iteration until we have actually read a valid key.
  • The loop does only three iterations, because this is the length of the array pin, which we would otherwise overflow.
Edgar Bonet
  • 45,094
  • 81
As an addition ToEdgar Bonets answer. I should warn you that your code keeps adding position in as each time you check array you are increasing the value of i. As a result you are filling arrays with NO_KEY.
Also having have build a security alarm on arduino before (Or shouldnt we know thats what you are doing?) I should warn you that waiting for Keyboard inputs mean that you are not checking tamper or alarm even when its armed because you are stucked inside nonloop function waiting for imput. I have personally made input a global struct
struct foo{
   char digits[4];
   byte digit=0;
} pinCode;
You can either take instance of the struct as a parameter to your function or because its global use it internaly.
bool addDigit(char button){
  /*here deal with many potential inputs*/
you can then inside your function assign the button pressed as
pinCode.digits[pinCode.digit]=button;
pinCode.digit++;
if you are passing the instance of the struct as a pointer then it will change to
pinCode->digits[pinCode->digit]=button;
pinCode->digit++;
you can then inside this funtion test if password is confirmed (OK is pressed) and return true.
While the end of the password isn't reached, just return false. SO within the loop you would have something like:
if(key!=NO_KEY){
   if(addDigit(key)) //Here take an action based on inputs
// Do all the other stuff alarm has to do
Tomas
  • 338
