I'm trying to pass a list of files (located in sketch) to be read using a library I write. List can have different filenames and vary in number of files.
How to pass a this array to my library?
for example:
char *parameterFiles[3] = {"/myIOT_param.json", "/myIOT2_topics.json", "/sketch_param.json"};
EDIT_1
To explain more clearly what are my needs: Let's say that my library has a class name myIOT2. That class holds an array that contains a list of all filenames (what shown here is not all class). Those names are different from one use of the library to the other, and it might not have all 4 files ( can be also 0 files stored ).
I wish to have the flexibilty not to hard code exact filename in advance, but to pass that array as part of my sketch, as show prior to EDIT_1.
class myIOT2
public:
const char *parameter_filenames[4] = {nullptr, nullptr, nullptr, nullptr};
guyd
  • 1,049
  • 26
  • 61
You have to pass both a pointer to the list, and the length of the list as an extra argument. The signature of the function may be something like:
void processFiles(const char *fileList[], int fileCount);
Note that const char *fileList[] is just a fancy way of writing const char **fileList. I find the former more readable, but that is completely subjective.
Here is a small test code showing this in action:
    for (int i = 0; i < fileCount; ++i) {
        Serial.print("Processing file ");
        Serial.println(fileList[i]);
const char *parameterFiles[3] = { "/myIOT_param.json", "/myIOT2_topics.json", "/sketch_param.json" };
void setup() { Serial.begin(9600); processFiles(parameterFiles, 3); }
void loop() {}
Alternatively, you may put a “sentinel” at the end of the list: a null pointer that signifies that the list ends there:
void processFiles(const char *fileList[])
    for (const char **p = fileList; *p; ++p) {
        Serial.println(*p);
const char *parameterFiles[] = { "/myIOT_param.json", "/myIOT2_topics.json", "/sketch_param.json", nullptr };
void setup() { Serial.begin(9600); processFiles(parameterFiles); }
void loop() {}
Edit: Answering to EDIT_1.
[My library's] class holds an array that contains a list of all filenames
First of all, you have to decide who is responsible for storing those file names: the library or its client. When you write:
you are creating 4 arrays: an array of 3 pointers named parameterFiles, and three arrays of characters holding the file names. Note that those 3 arrays are anonymous: they are not array variables. If the client code tries to pass this parameterFiles to your library, the array identifier will decay to a pointer, and your library will receive that pointer. What should it do with it?
  1. The library could just keep a copy of the pointer. The client is then responsible for ensuring that it remains valid for as long as the library may need it. This practically implies that parameterFiles should be a global variable, and should not be modified once given to the library.
  2. The library could make a copy of the array. Then the client is freed from this responsibility. However, it is still responsible for ensuring that the pointers that were copied from the array remain valid, i.e. that the file names stay in the same place in memory.
  3. The library could copy the file names themselves. Then the client doesn't have any responsibility about keeping pointers valid.
If you choose option 2 or 3, the library will have to hold one or more arrays. You will then have to choose whether you allocate them statically, or dynamically with new. Dynamic allocation is more efficient when the arrays can vary greatly in length, but it can raise issues of memory fragmentation in RAM-constrained devices.
I cannot tell you which option is best: it depends on your use case. In any case, whatever you choose, you should document it: the user of the library should know whether they are responsible for keeping any pointers valid.
In the following, I will assume option 2 with static allocation. This is consistent with the code snippets in your question. Also, if the client provides the file names as string literals, then pointers to these strings remain always valid.
Here is a toy implementation of the myIOT2 class, where the list of file names is copied by the constructor into the class:
class myIOT2 : public Printable
public:
    static const int maxFileCount = 4;
myIOT2(const char *fileList[], int count) {
    if (count &gt; maxFileCount)
        count = maxFileCount;  // discard extra files
    fileCount = count;
    for (int i = 0; i &lt; fileCount; i++)
        filenames[i] = fileList[i];
size_t printTo(Print&amp; p) const {
    size_t count = p.print(F(&quot;myIOT2[&quot;));
    for (int i = 0; i &lt; fileCount; i++) {
        count += p.print('&quot;');
        count += p.print(filenames[i]);
        if (i &lt; fileCount - 1)
            count += p.print(&quot;, &quot;);
    count += p.print(']');
    return count;
private: const char *filenames[maxFileCount]; int fileCount; };
Note that, the array of file names being statically allocated, there is a hard maximum on the number of files that can be stored. I made the class Printable only for debugging convenience.
And here is an example of this class in use:
const int fileCount = 3;
const char *parameterFiles[fileCount] = { "/myIOT_param.json", "/myIOT2_topics.json", "/sketch_param.json" };
myIOT2 iot(parameterFiles, fileCount);
void setup() { Serial.begin(9600); Serial.println(iot); }
void loop() {}
This test sketch prints:
myIOT2["/myIOT_param.json", "/myIOT2_topics.json", "/sketch_param.json"]
Edgar Bonet
  • 45,094
  • 81
