Note: This is a reference question (but feel free to write answers of your own!)
I want to use the AVR tools directly -- no arduino-builder or arduino-cli. I would also like compilation and uploading to be as fast as reasonably possible
Makefile in your project directory. Populate it with the following contents:TEMPDIR := $(shell mktemp -d)
all:
avr-g++ -DF_CPU=<CLK> -mmcu=<PARTNO> -fno-threadsafe-statics -O3 -flto -std=c++23 -isystem/usr/avr/include -lm -fuse-linker-plugin -Wl,--gc-sections *.cpp -o ${TEMPDIR}/a.elf
avr-objcopy -O ihex -R .eeprom ${TEMPDIR}/a.elf ${TEMPDIR}/a.hex
avrdude -V -p<PARTNO> -carduino -P/dev/tty<SERIAL_PORT> -b<BAUD> -D -Uflash:w:${TEMPDIR}/a.hex
rm ${TEMPDIR}/a.elf ${TEMPDIR}/a.hex
rm -d ${TEMPDIR}
<CLK>) with the values in the Arduino IDE's build output.make.-lm links in the AVR math library. *.cpp refers to your c++ source files. -V prevents avrdude from reading back the flash contents and verifying it, which saves time, but you may want to disable it while diagnosing problems.
