I want my reference voltatge to be 1.1v so that by dividing it to
1023 parts I will have the accuracy of about 1mv.
You will have a resolution of about 1 mV. The accuracy will be
significantly worse than that due to the imperfections of the ADC
(offset error, gain error, non-linearity) and noise.
how should I edit the mentioned code in order to do so?
The reference is configured by the bits REFS0 and REFS1 of the
ADMUX register. The internal 1.1 V reference is selected by
setting both bits, as shown in table 24-3 of the
datasheet. You can then patch the original code like this:
@@ -8,7 +8,7 @@
ADCSRA = 0; // clear ADCSRA register
ADCSRB = 0; // clear ADCSRB register
ADMUX |= (0 & 0x07); // set A0 analog input pin
- ADMUX |= (1 << REFS0); // set reference voltage
+ ADMUX |= (1 << REFS0) | (1 << REFS1); // set reference voltage
ADMUX |= (1 << ADLAR); // left align ADC value to 8 bits from ADCH register
// sampling rate is [ADC clock] / [prescaler] / [conversion clock cycles]
the code in the void loop() setup is of no use for me (I prefer not
to save the measured data on the arduino and then send to my pc
because of memory limitations). after deleting it will the data still
be sent to the serial port?
In the linked code, loop() is the only function sending anything to
the serial port. If you remove it, nothing will be sent. You could
Serial.write() in the ISR though, in which case an empty loop()
would be fine.
Note that writing to Serial from within an ISR is generally
discouraged. Your situation though (an oscilloscope code) is one of the
very few cases where it does make sense to do so.
will sending the data through the serial port affect my sample
rate/accuracy?
It can certainly affect your sampling rate. Serial.write() is usually
non-blocking, as all it does is write the data to the RAM-based transmit
buffer. If the buffer fills up, however, Serial.write() will block
waiting for the serial port to actually send the data, and make enough
room in the buffer.
This means that, in order for the oscilloscope to not miss samples, you
have to make sure that the serial port can send the data at least as
fast as the ADC is acquiring it.
Example calculation: If you clock the ADC at 1 MHz, you get one
sample every 13 µs. You can follow the example given in the code
you linked to, and discard the last two bits in order to transmit only
8 bits of the sample. Transmitting those in plain binary will take
10 “bits” worth of the serial port bandwidth (one start bit,
8 data bits and one stop bit). Each bit should then take less than
1.3 µs, which translates to a baud rate of 769,231 bits per
second. You will probably have no other choice than configuring the
serial port for 1 Mb/s.
If you want to transmit the whole 10 bits of the ADC readings, you
will have to lower the sampling rate by a factor two.
At this point you may notice that the serial port, rather than the ADC,
is the bottleneck for the performance of your oscilloscope. If this is
too limiting, you may consider building a scope that works by bursts: it
stores a burst of samples in memory, then sends it at a leisurely rate
through the serial port.
