I have analog accelerometer that transfer acceleration on 3 axis with frequency 5 kHz. I want to store that data in SD card for in txt file. My sketch is the following:
void loop()
// Get raw accelerometer data for each axis
int rawX = analogRead(A0);
int rawY = analogRead(A1);
int rawZ = analogRead(A2);
// Scale accelerometer ADC readings into common units
// Scale map depends on if using a 5V or 3.3V microcontroller
float scaledX, scaledY, scaledZ; // Scaled values for each axis
if (micro_is_5V) // Microcontroller runs off 5V
scaledX = mapf(rawX, 0, 1023, -scale, scale); // 3.3/5 * 1023 =~ 675
scaledY = mapf(rawY, 0, 1023, -scale, scale);
scaledZ = mapf(rawZ, 0, 1023, -scale, scale);
else // Microcontroller runs off 3.3V
scaledX = mapf(rawX, 0, 675, -scale, scale);
scaledY = mapf(rawY, 0, 675, -scale, scale);
scaledZ = mapf(rawZ, 0, 675, -scale, scale);
String dataString = "";
// Concatenate string
dataString += String(scaledX);
dataString += "\t\t";
dataString += String(scaledY);
dataString += String(scaledZ);
saveSD();
// Same functionality as Arduino's standard map function, except using floats
float mapf(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
void saveSD()
// create file for writing
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if file is available
if (dataFile) {
// save the data
dataFile.println(dataString);
// close file
dataFile.close();
} else {
// if file is unavailable
Serial.println("Error opening datalog.txt");
So in loop I open file, write to it and after that close it. When my file will be big enough there will be bottle neck.It will take a lot of time to read and write file. How to deal with saving data to files on SD card?
UPD: I measured the time of executing code like that:
start_open_t=micros(); // time in milli seconds
delta_open_t=micros() - start_open_t ;
// if file is available for writing
if (dataFile) {
// save the data
start_write_t=micros(); // time in milli seconds
delta_write_t=micros() - start_write_t ;
// close the file
start_close_t=micros(); // time in milli seconds
dataFile.close();
delta_close_t=micros() - start_close_t ;
And there is the result:
Open time:
7656
Write time:
2176
Close time:
8076
The open time is increasing there is no surprise (with increasing the file size).
Write to file and close time is almost constant.
I thought to open file in setup() and initialize timer. Write to file in loop() and after some time interval to close the file, after that open new file and so on. But as can be seen the print operation dataFile.println(dataString); takes approximately 2 ms that is 500 Hz, and it is too slow. I need to register with 5 kHz.
If I print in serial the data is printed much faster but I can not connect to usb because arduino is located to far (approx 30 meters).
May be there is the way to connect to serial with wifi or bluetooth or may be there are another methods to store the data fast?
