Explain in a simple example. How to pass a char* to a function?
#define name1 "ABCD"
#define name2 "EFGH"
#define name3 "HIJK"
char *list[3] = {};
void printList(char *l, int x) { for (int i = 0; i < x; i++) { Serial.println(l[i]); }
void setup() { // put your setup code here, to run once: Serial.begin(115200); Serial.println("start"); list[0] = name1; list[1] = name2; list[2] = name3;
printList(list, 3);
void loop() { // put your main code here, to run repeatedly:
I get an error:
/home/guy/Documents/Dropbox/Arduino/sketch_jun12a/sketch_jun12a.ino: In function 'void setup()':
sketch_jun12a:24:13: error: cannot convert 'char**' to 'char*'
   24 |   printList(list, 3);
      |             char**
/home/guy/Documents/Dropbox/Arduino/sketch_jun12a/sketch_jun12a.ino:7:22: note:   initializing argument 1 of 'void printList(char*, int)'
    7 | void printList(char *l, int x) {
exit status 1
guyd
  • 1,049
  • 26
  • 61
Just change this:
to this:
void printList(char **l, int x) {
OK, this deserves some explanation...
In C and C++, when you use (not when you define) an array identifier, it decays to a pointer to its first element. In this case,
char *list[3] = {};
is an array of pointers to char. When you use it here:
printList(list, 3);
it decays to a pointer to pointer to char. Thus the double * needed in the parameter declaration.
Side note: to get really correct C++, you should replace every instance of char by const char. This is because the characters in question belong to string literals, and you are not allowed to modify a string literal at run time.
Edgar Bonet
  • 45,094
  • 81
