When i try to upload code to the esp32 the following error shows up in the command line:
A fatal error occurred: Packet content transfer stopped (received 8 bytes).
I use platformio in VScode the platform.ini file looks like this:
    [env:esp-wrover-kit]
    platform = espressif32
    board = esp-wrover-kit
    framework = arduino
    upload_port = COM4
    monitor_speed = 115200
Here's the code i'm trying to upload:
#include <Arduino.h>
void setup() { Serial.begin(115200); Serial.println("init"); }
void loop() { }
It's an esp32-wrover-dev from freenove. When i unplug it and plug it back in it starts to write random stuff to the serial monitor, when i attempt an upload it stops but it also gives me the error above.
exo
  • 67
I had this error when trying to upload a sketch from Arduino IDE to a TTGO T-Display, found that I could resolve this by changing the upload speed from the default of 921600 to 115200.
After doing that it uploaded just fine with no issues.
steoleary
  • 171
I was able to resolve this issue by detaching jumpers that i had connected to the GPIO 12/13 pins during upload.
After uploading they can be attached again. See this github issue: https://github.com/espressif/arduino-esp32/issues/2415
Trizion
For anyone wondering, i found out it means that there's some kind of disconnect between the computer from which your uploading and the file system. Essentially, the esp32 is broken.
exo
  • 67
Hi all I found I got this error because my FTDI adapter was in 3.3V mode, not 5V as soon as I set it to 5V the issue was resolved and it programmed fine. One more thing to check before you scrap your ESP32.
Mick
