I have connected my Arduino UNO through USB to Raspberry pi 3B. I am using CLI for editing, compiling and uploading sketches > arduino-cli upload --fqbn arduino:avr:uno cli-test. However, after attempting to upload the sketch, it throws the error, Error during Upload: Failed uploading: no upload port provided I even checked if the Arduino is detected on the respective port using arduino-cli board list and it shows
/dev/ttyACM0 serial   Serial Port (USB) Arduino Uno arduino:avr:uno arduino:avr
/dev/ttyAMA0 serial   Serial Port       Unknown
The support forum of Arduino says to 'select' the port. Nevertheless the support forum resolves the error for GUI application and not for CLI. I searched for how to select the port in CLI, but in vain. Any help is appreciated.
DaSnipeKid
You specify the port with the --port flag to the upload command:
$ arduino-cli upload --fqbn arduino:avr:uno --port /dev/ttyACM0 cli-test
You can find all these things out for yourself by using --help at any time. For example:
$ arduino-cli upload --help
Upload Arduino sketches. This does NOT compile the sketch prior to upload.
Usage: arduino-cli upload [flags]
Examples: arduino-cli upload /home/user/Arduino/MySketch
Flags: --board-options strings List of board options separated by commas. Or can be used multiple times for multiple options. --discovery-timeout duration Max time to wait for port discovery, e.g.: 30s, 1m (default 1s) -b, --fqbn string Fully Qualified Board Name, e.g.: arduino:avr:uno -h, --help help for upload --input-dir string Directory containing binaries to upload. -i, --input-file string Binary file to upload. -p, --port string Upload port address, e.g.: COM3 or /dev/ttyACM2 -P, --programmer string Programmer to use, e.g: atmel_ice -l, --protocol string Upload port protocol, e.g: serial -t, --verify Verify uploaded binary after the upload.
Global Flags: --additional-urls strings Comma-separated list of additional URLs for the Boards Manager. --config-file string The custom config file (if not specified the default will be used). --format string The output format for the logs, can be: text, json, jsonmini, yaml (default "text") --log-file string Path to the file where logs will be written. --log-format string The output format for the logs, can be: text, json --log-level string Messages with this level and above will be logged. Valid levels are: trace, debug, info, warn, error, fatal, panic --no-color Disable colored output. -v, --verbose Print the logs on the standard output.
Majenko
  • 105,851
  • 82
  • 139
