I know that the topic is not related to Arduino, but I am completely sure that someone can help me find the problem. I am testing 6 temperature sensors, (3 digital, 3 analog). The digital ones are "DS18B20" which I trust, the analog ones are "MCP9701A", "TC1047A" and "MCP9700A".
By reading the analog sensors using Arduino Uno or Arduino Mega, the results of the 6 sensors are almost identical and I don't face any problem. But when make the test using the ESP32-devkitc-v4, I obtain wrong reading from the 3 analog sensors. In the code "serial monitor", I obtain a voltage value completely different from the one I measure physically by a multi-meter.
For example:
The 3 digital sensors a giving the value of 23.56C to 23.81C but for the "MCP9701A" analog sensor I obtain 16.26C and the voltage obtain in the serial monitor is 0.718 volts, however it is 0.851 volts by the multi-meter. And according to the calculations from the data-sheet: (0.851-0.4)/(19.5mVolts)= 23.12C which is so close to the digital sensors. I have the same problem with the other analog sensors, so if you can help me find my error, I will appreciate it.
Here are the data-sheets of the analog sensors:
MCP9701A and MCP9711A
https://ww1.microchip.com/downloads/en/DeviceDoc/20001942G.pdf
TC1047A
https://ww1.microchip.com/downloads/en/DeviceDoc/21498D.pdf
Here is my code:
#include <OneWire.h>
#include <DallasTemperature.h>
#include "driver/adc.h"
// GPIO where the DS18B20 is connected to const int oneWireBus = 4;
// Setup a oneWire instance to communicate with any OneWire devices OneWire oneWire(oneWireBus);
// Pass our oneWire reference to Dallas Temperature sensor DallasTemperature sensors(&oneWire);
#define analogInPin0 35 #define analogInPin1 32 #define analogInPin2 33
float analogTempTC1047=0.0; float analogTempMCP9700=0.0; float analogTempMCP9701=0.0;
float volt0=0.0; float volt1=0.0; float volt2=0.0;
int sensorValue0 = 0; int sensorValue1 = 0; int sensorValue2 = 0;
void setup() { // Start the Serial Monitor Serial.begin(9600); // Start the DS18B20 sensor sensors.begin(); }
void loop() { // put your main code here, to run repeatedly: sensorValue0 = analogRead(analogInPin0); sensorValue1 = analogRead(analogInPin1); sensorValue2 = analogRead(analogInPin2);
volt0= (3.3/4096.0)*sensorValue0; analogTempMCP9701= ((volt0-0.4)/0.0195);
volt1= (3.3/4096.0)*sensorValue1; analogTempTC1047= ((volt1-0.5)/0.01);
volt2= (3.3/4096.0)*sensorValue2; analogTempMCP9700= ((volt2-0.5)/0.01);
sensors.requestTemperatures(); float temperatureC1 = sensors.getTempCByIndex(0); float temperatureC2 = sensors.getTempCByIndex(1); float temperatureC3 = sensors.getTempCByIndex(2); Serial.print("S1= "); Serial.print(temperatureC1); Serial.print("ºC"); Serial.print(", S2= "); Serial.print(temperatureC2); Serial.print("ºC"); Serial.print(", S3= "); Serial.print(temperatureC3); Serial.print("ºC,------- ");
Serial.print("input sensor1= "); Serial.print(sensorValue0); Serial.print(", volt1= "); Serial.print("= "); Serial.print(volt0, 3); Serial.print(", Analog sensor MCP9701 = "); Serial.print(analogTempMCP9701);
Serial.print("----"); Serial.print("input sensor2= "); Serial.print(sensorValue1); Serial.print(", volt2= "); Serial.print("= "); Serial.print(volt1, 3); Serial.print(" --Analog sensor TC1047 = "); Serial.print(analogTempTC1047);
Serial.print("----"); Serial.print("input sensor3= "); Serial.print(sensorValue2); Serial.print(", volt2= "); Serial.print("= "); Serial.print(volt2, 3); Serial.print(" --Analog sensor MCP9700 = "); Serial.println(analogTempMCP9700); delay(4000); }
And here is the serial monitor output:
S1= 23.56ºC, S2= 23.81ºC, S3= 23.50ºC,------- input sensor1= 895, volt1=  = 0.721, Analog sensor MCP9701 = 16.47----input sensor2= 747, volt2=  = 0.602 --Analog sensor TC1047 = 10.18----input sensor3= 752, volt2=  = 0.606 --Analog sensor MCP9700 = 10.59
S1= 23.56ºC, S2= 23.75ºC, S3= 23.50ºC,------- input sensor1= 894, volt1=  = 0.720, Analog sensor MCP9701 = 16.42----input sensor2= 747, volt2=  = 0.602 --Analog sensor TC1047 = 10.18----input sensor3= 755, volt2=  = 0.608 --Analog sensor MCP9700 = 10.83
S1= 23.56ºC, S2= 23.75ºC, S3= 23.50ºC,------- input sensor1= 905, volt1=  = 0.729, Analog sensor MCP9701 = 16.88----input sensor2= 746, volt2=  = 0.601 --Analog sensor TC1047 = 10.10----input sensor3= 753, volt2=  = 0.607 --Analog sensor MCP9700 = 10.67
Gil Sven
  • 167
KamelK
Not a full answer, only a direction to consider:
The ESP32 ADC seems to be shipped with a ADC calibration tolerance of ±6%, as stated in the ESP32 datasheet, chapter 4.1.2. Here are the calibration docs.
It seems like you're still off by more than those 6% (didn't calculate it through). Maybe your power supply is a bit weak, pulling the internal reference voltage down?
orithena
  • 499
