In my current project I need to store the current elapsed time in hours to retrieve it in case of power loss. Since I am using a Arduino Nano I would ideally like to use the built in EEPROM without additional hardware.
The written values and their order will always be:
0 -> 1 -> 2 -> 3 -> 4 -> 5 -> 6 -> 0 -> ....
If I write that on EEPROM per 0->0 full cycle the last bit will change 7 times and the other bits are pretty much idle. That's why I thought of distributing the changes more evenly by using instead the sequence
0 -> 1 -> 3 -> 7 -> 15 -> 31 -> 63 -> 0 -> ....
This would change every bit only once during a full 0->0 cycle. Does this improve EEPROM life expectancy or is the life expectancy linked to updating full bytes rather than individual bits?
edit: Since the question was closed for being off-topic, I altered the introduction a little bit. I am sorry if some of the comments are no longer fully valid. Since I don't fully understand why the question was closed (especially since there is EEPROM-tag), I would be grateful for a tip where on stackexchange the question would be best suited.
maxmilgram
  • 151
On your next design consider using FRAM, it is non volatile and supports almost unlimited (10 - 14th) read write cycles. The library I use or EEPROM supports the update function where it reads the memory first and does not write to it if it is to remain unchanged.
Gil
  • 1,863
It is possible to write to ATmega EEPROM address without clearing its previous value. The write mode is set with the EEPMx bits in the EECR register.
The avr-libc eeprom.h write functions only use the erase and write mode and the Arduino EEPROM library only uses avr-libc eeprom.h write function.
I modified the EEPROM_write example function from the datasheet to write without erase.
#include <EEPROM.h>
Serial.begin(115200);
int address = 0;
EEPROM.write(address, 0b11111111); Serial.println(EEPROM.read(address), BIN);
EEPROM_write_no_erase(address, 0b11111110); Serial.println(EEPROM.read(address), BIN);
EEPROM_write_no_erase(address, 0b11111101); Serial.println(EEPROM.read(address), BIN);
EEPROM_write_no_erase(address, 0b11101111); Serial.println(EEPROM.read(address), BIN);
void EEPROM_write_no_erase(unsigned int uiAddress, unsigned char ucData) { /* Wait for completion of previous write / while (EECR & (1 << EEPE)) ; / Set up address and Data Registers / EEAR = uiAddress; EEDR = ucData; / Write only / EECR |= (1 << EEPM1); EECR &= ~(1 << EEPM0); / Write logical one to EEMPE / EECR |= (1 << EEMPE); / Start eeprom write by setting EEPE */ EECR |= (1 << EEPE); }
the output is as expected:
11111111
11111110
11111100
11101100
I don't know if use of this feature improves the lifetime of the ATmega EEPROM.
Juraj
  • 18,264
  • 49
