So first off, I know millis() exists. Just asking out of curiosity. Say you have a button you wanna check for during a delay.. Maybe a 10 second delay. So you make a for loop that checks for input and delays 1 ms... 10,000 times. What's bad about this?
 int pin = 13;
    bool button = false;
void setup()
  pinMode(pin, INPUT);
void loop()
 while(button == false) {
 for(int i = 0; i<10000; i++) {
 if(digitalRead(pin,HIGH){
 button = true;
} delay(1);
BobaJFET
  • 135
You can do this, for quite simple sketches. It starts to become ugly if you add more features and conditions.
Therefore, the "correctTM" (read: professional) way is to implement a state machine. See in the IDE the non-delay blink example.
const unsigned long DELAY_MS = 1000;
int pin = 13;
enum State { WAITING, WORKING, };
State state;
unsigned long startTime;
void setup() { pinMode(pin, INPUT); state = WAITING; startTime = millis(); }
void loop() { switch (state) { case WAITING: // You can put both conditions in one "if" with an "||" operator. // But it will look less clear. if (millis() - startTime > DELAY_MS) { state = WORKING; } else if (digitalRead(pin)) { state = WORKING; } break; case WORKING: // anything to do after the delay or the button break; default: // any error handling you see fit break; } }
The function loop() is designed to be called endlessly in repetition. Use this to your advantage.
the busybee
  • 2,408
It looks a bit clunky but I suppose there is nothing particularly bad about it (apart from your typo of digitalWrite rather than digitalRead).
I would do it more like:
unsigned long now = millis ();
button = LOW;
while ((millis () - now < 10000) && (button == LOW)) button = digitalRead (pin);
Nick Gammon
  • 38,901
Ok, millis is always the best way...
Say you have a button you wanna check for during a delay.. So you make a for loop that checks for input and delays 1 ms... 10,000 times.
Your code is not really doing what you want. Your while loop never ends until button is pressed so 10s delay has no sense. I suppose your code should exit after 10 seconds or if button is pressed.
You're code, without millis(), should be
  uint16_t ms2wait = 10000;
  while (button == false && --ms2wait > 0) {
      button = true;
    delay(1);
Marco Cogo
  • 56
