I tried to connect my RFM69HCW to Arduino Nano 33 BLE, so that I won't be needing a logic level shifter to downgrade the voltage, since Arduino Nano is already 3.3V. Upon checking its data sheet and pinout, I noticed there's no dedicated pin for CS (Chip Select).
Which pin should I use as CS in the Arduino Nano?
Which pin should I connect the DI0 pin of RFM69HCW in the Arduino Nano?
dda
  • 1,595
There is no dedicated CS pin, and you can use any available Dx pin – which enables you, among other things, to have several devices on the same bus. The CS pin allows you to select (hence the S) the right device.
dda
  • 1,595
On any Arduino you can use any free digital pin as SPI CS.
Juraj
  • 18,264
  • 49
