I have found the following code and it works fine on a breadboard controlling small LEDs but I want it to work with LED strip lighting with external 240v transformers. We have built the circuit using a 5v to 240v relay and the connections are functional but the code does not seem to translate. Does the built in blink class in Arduino function with relays? As it is either High or Low with no variation in voltage I don't see why it wouldn't work as a switch. Has anyone got any suggestions? Thank you
class LED
  public :
LED();
void init( uint8_t pin );
void update();
void toggle( bool const on );
void on()  { toggle( true  ); };
void off() { toggle( false ); };
void blink( uint16_t const * const pattern, size_t const length, int8_t const count = -1 );
void blink( uint16_t const timeOn = 1000, uint16_t const timeOff = 1000, int8_t const count = -1 );
void flash( uint16_t const timeOn );
private :
uint8_t          m_pin;
bool             m_isOn;
uint32_t         m_millis;
uint16_t         m_time;
int8_t           m_count;
uint16_t const * m_patternPtr;
uint16_t         m_pattern[2];
size_t           m_patternLength;
size_t           m_patternIndex;
void write( bool const on );
LED::LED() : m_pin ( 255 ) , m_isOn ( false ) , m_millis ( 0 ) , m_time ( 0 ) , m_count ( 0 ) , m_patternPtr ( nullptr ) , m_pattern { 0, 0 } , m_patternLength ( 0 ) , m_patternIndex ( 0 ) { }
void LED::init( uint8_t pin ) { m_pin = pin; pinMode( pin, OUTPUT ); write( false ); }
void LED::toggle( bool const on ) { m_count = 0; m_patternPtr = nullptr; m_patternIndex = 0; m_patternLength = 0; write( on ); }
void LED::write( bool const on ) { m_isOn = on; digitalWrite( m_pin, on ? HIGH : LOW ); }
void LED::blink( uint16_t const * const pattern, size_t const length, int8_t const count ) { if ( count != 0 && length > 0 && pattern != nullptr ) { write( true ); m_millis = millis(); m_count = count; m_patternPtr = pattern; m_patternLength = length; m_patternIndex = 0; m_time = m_patternPtr[0]; } }
void LED::blink( uint16_t const timeOn, uint16_t const timeOff, int8_t const count ) { m_pattern[0] = timeOn; m_pattern[1] = timeOff; blink( m_pattern, 2, count ); }
void LED::flash( uint16_t const timeOn ) { m_pattern[0] = timeOn; blink( m_pattern, 1, 1 ); }
void LED::update() { if ( m_count != 0 && millis() - m_millis >= m_time ) { if ( m_patternLength == 1 ) { toggle( false ); } else if ( ++m_patternIndex < m_patternLength ) { m_time = m_patternPtr[ m_patternIndex ]; } else { if ( m_count != -1 ) { m_count--; }
  if ( m_count == 0 )
    toggle( false );
  else
    m_patternIndex = 0;
if ( m_count != 0 )
  write( !m_isOn );
LED led1; LED led2; LED led3;
void setup() { led1.init( 10 ); led2.init( 11 ); led3.init( 9 );
// 2 flashs toutes les secondes on off on off static const uint16_t led1_pattern[] = { 100, 100, 2000, 400, 5000, 5000, 1000, 200 }; led1.blink( led1_pattern, 8 );
// 2 flashs toutes les deux secondes on off on off static const uint16_t led2_pattern[] = { 2000, 100, 250, 1400, 2000, 400, 800 }; led2.blink( led2_pattern, 8);
// 2 flashs toutes les secondes on off on off static const uint16_t led3_pattern[] = { 100, 5000, 2000, 400, 5000, 500, 1000, 2000 }; led3.blink( led3_pattern, 8 );
void loop() { led1.update(); led2.update(); led3.update(); }
sempaiscuba
  • 1,042
Zed
