I have project with an ESPAsyncWebServer with websockets working already. What I need to add is Client functionality to poll a site for a response. I looked at the ASyncTCP library and it has two different implementations that aren't well documented in how to use.
There's the SyncClient option that looks like this:
SyncClient client;
if(!client.connect("www.google.com", 80)){
Serial.println("Connect Failed");
return;
client.setTimeout(2);
if(client.printf("GET / HTTP/1.1\r\nHost: www.google.com\r\nConnection: close\r\n\r\n") > 0){
while(client.connected() && client.available() == 0){
delay(1);
while(client.available()){
Serial.write(client.read());
if(client.connected()){
client.stop();
} else {
client.stop();
Serial.println("Send Failed");
while(client.connected()) delay(0);
I don't know if i'm supposed to put code after a client.connected() or client.available()? Of if I need the full structure as shown or just one of the commands. It also doesn't show all the commands and syntax available (such as an equivalent for client.write(), client.print or the like).
Then there is the simply named ClientServer > Client which only has the following:
static void replyToServer(void* arg) {
AsyncClient* client = reinterpret_cast<AsyncClient*>(arg);
// send reply
if (client->space() > 32 && client->canSend()) {
char message[32];
sprintf(message, "this is from %s", WiFi.localIP().toString().c_str());
client->add(message, strlen(message));
client->send();
/* event callbacks /
static void handleData(void arg, AsyncClient* client, void data, size_t len) {
Serial.printf("\n data received from %s \n", client->remoteIP().toString().c_str());
Serial.write((uint8_t)data, len);
os_timer_arm(&intervalTimer, 2000, true); // schedule for reply to server at next 2s
void onConnect(void* arg, AsyncClient* client) {
Serial.printf("\n client has been connected to %s on port %d \n", SERVER_HOST_NAME, TCP_PORT);
replyToServer(client);
Serial.begin(115200);
delay(20);
// connects to access point
WiFi.mode(WIFI_STA);
WiFi.begin(SSID, PASSWORD);
Serial.print('.');
delay(500);
AsyncClient* client = new AsyncClient;
client->onData(&handleData, client);
client->onConnect(&onConnect, client);
client->connect(SERVER_HOST_NAME, TCP_PORT);
os_timer_disarm(&intervalTimer);
os_timer_setfn(&intervalTimer, &replyToServer, client);
This doesn't tell me a whole lot about how to use this library.
I need some guidance on how to deploy the client alongside my server. I don't need much, just listen for server directive, parse it and then send a response (client.println) or upload a file (client.write). I'd like to implement the asynchronous version of this.
