I'm a little dumbfounded as to why this isn't working. I keep getting the following linker error:
In file included from src\ac.cpp:1:0:
src/ac.h:9:21: error: expected identifier before numeric constant
 #define RECEIVE_PIN 0
src/ac.h:14:26: note: in expansion of macro 'RECEIVE_PIN'
     static IRrecv irrecv(RECEIVE_PIN);
src/ac.h:9:21: error: expected ',' or '...' before numeric constant
*** [.pio\build\esp32cam\src\ac.cpp.o] Error 1
*** [.pio\build\esp32cam\src\main.cpp.o] Error 1
I am simply trying to initialize the IR receiver with static IRrecv irrecv(RECEIVE_PIN);, but the compiler is refusing to link it together.
#ifndef _AC_H_
#define _AC_H_
#include <Arduino.h> #include <IRremoteESP8266.h> #include <IRrecv.h> #include <IRutils.h>
class IR { public: static IRrecv irrecv(RECEIVE_PIN); static decode_results results; void initRecv(); bool waitForIR(); };
extern IR ir;
#endif
If I do static IRrecv irrecv; it successfully compiles, but I'm unsure if I can pass the pin variable after the fact.
Jeebus
Static data members have to be defined outside the class declaration. The initialization happens at the point where the members are defined:
file ac.h:
class IR { public: // Static data members are declared only: static IRrecv irrecv; static decode_results results; void initRecv(); bool waitForIR(); };
file ac.cpp:
#include "ac.h"
// Definitions and initializations of static data members: IRrecv IR::irrecv(RECEIVE_PIN); decode_results IR::results;
Edgar Bonet
  • 45,094
  • 81
