I started using an Arduino Uno days ago. I'm an experienced C++ dev and I'm kind of confused.
Is the Arduino compiler different than a C++ one? What C++ version does Aruidno Uno use? Why it doesn't it support STL? Is it possible to use STL?
Also, can I configure their cpp file and use my own main function? The loop / setup thing really does annoy me. Thanks!
Mat
  • 464
ZakiMkn
Yes, there are STL implementations for the Arduino Uno (check the library manager). Note that some of them are unsupported and/or outdated quite a bit. The downside of using STL on the Arduino is also that these classes may use to much memory. Because of it's very limited memory (only 2kb), dynamic memory allocation is quite risky, as memory fragmentation will quickly cause the program to crash.
The Arduino build system uses a pre-build step around the ino files that remove a lot of pain locating header files and setting up build paths from the user. This is a bit confusing at first for an experienced C++ programmer, but it simplifies things a lot, particularly when it comes to using different libraries. This build step automatically locates the include paths for all .h files referenced in the .ino. The system requires that you declare the loop() and setup() methods, but what you do with them is up to you. You can leave either of them empty, or never return from the loop function, calling into whatever main function you want to use.
As a side note: There are other C++ compiler features that are disabled or unsupported on the Uno because they would make the code to big. These include dynamic type casting using dynamic_cast<> and exception handling.
PMF
  • 1,306
