I have created my own custom Arduino Micro, but I am experiencing problems when I attempt to upload an sketch via USB in Arduino IDE.
Here is how I program the Arduino Micro:
avrdude  -c atmelice_isp  -p m32u4 -P usb -u -v -e -U flash:w:Caterina-Micro.hex
And the result:
$ avrdude  -c atmelice_isp  -p m32u4 -P usb -v -e -U flash:w:Caterina-Micro.hex
avrdude: Version 6.1, compiled on Mar 23 2014 at 04:42:55
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/usr/local/Cellar/avrdude/6.1/etc/avrdude.conf"
         User configuration file is "/Users/aUser/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : atmelice_isp
avrdude: usbdev_open(): Found Atmel-ICE CMSIS-DAP, serno: J41800023270
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : JTAG3_ISP
         Description     : Atmel-ICE (ARM/AVR) in ISP mode
         Vtarget         : 4.9 V
         SCK period      : 125.00 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9587
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as CB
avrdude: erasing chip
avrdude: reading input file "Caterina-Micro.hex"
avrdude: input file Caterina-Micro.hex auto detected as Intel Hex
avrdude: writing flash (32730 bytes):
Writing | ################################################## | 100% 38.80s
avrdude: 32730 bytes of flash written
avrdude: verifying flash memory against Caterina-Micro.hex:
avrdude: load data flash data from input file Caterina-Micro.hex:
avrdude: input file Caterina-Micro.hex contains 32730 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 133.93s
avrdude: verifying ...
avrdude: 32730 bytes of flash verified
avrdude: safemode: Fuses OK (E:CB, H:D8, L:FF)
avrdude done.  Thank you.
The error in Arduino IDE when flashing sketch via USB:
Sketch uses 23.994 bytes (83%) of program storage space. Maximum is 28.672 bytes.
Global variables use 1.145 bytes (44%) of dynamic memory, leaving 1.415 bytes for local variables. Maximum is 2.560 bytes.
Forcing reset using 1200bps open/close on port /dev/tty.usbmodem1411
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.Bluetooth-Modem, /dev/cu.usbmodem1411, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Modem, /dev/tty.usbmodem1411, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.Bluetooth-Modem, /dev/cu.usbmodem1411, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.Bluetooth-Modem, /dev/tty.usbmodem1411, } => {}
Uploading using selected port: /dev/tty.usbmodem1411
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/tty.usbmodem1411 -b57600 -D -Uflash:w:/var/folders/64/6n0yv9515hz1n6z3bdzcwv6h0000gn/T/build2162381950044145986.tmp/IMUNode.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr  3 2014 at 22:00:33
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : /dev/tty.usbmodem1411
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
sa_leinad
  • 3,218
JavaCake
  • 139
Your problem is that your board doesn't have the bootloader loaded into the chip.
You have success with the ATMEL-ICE ISP because it is an in-system programmer (ISP) and you are downloading the code directly into the chip.
When you use the USB, I see from your output that the programmer is "butterfly" and the description indicates AVR109. These both indicate that the program is trying to be loaded through a bootloader.
A bootloader is a bit of code that resides in the codespace section of flash. It allows you to send the program through the UART. The bootloader then saves it to the codespace section of flash such that both the bootloader and your program co-exist.
To fix this, use the Arduino IDE along with your ATMEL-ICE ISP to load the bootloader into the microcontroller. This can be done by going into Tools and then Burn Bootloader (of course with the correct programmer selected).
This will then allow you to download your code through the Arduino IDE.
PS. You can program your sketch straight to your Arduino using your ATMEL-ICE ISP without downloading the bootloader. Do this by selecting the Upload Using Programmer option in the menus.
sa_leinad
  • 3,218
