I would like to save my Circular Buffer in the RTC memory of my ESP32 when I use deep sleep. So I have initialized it with RTC_DATA_ATTR but when I go into Deep Sleep I lose the data I've saved. Is there a way to do this?
Here is my function:
RTC_DATA_ATTR CircularBuffer<Datas, 178> test_SensorsDatas;
void test_RTC_memory(){
for(int i=1; i<=20; i++){
test_SensorsDatas.push(Datas);
ID_msg.value++;
for(int i=0; i<test_SensorsDatas.size(); i++){
Serial.println(String(Datas.value));
esp_deep_sleep_start();
Thank you very much! Ask me questions if something isn't clear ;)
EDIT: I tried something much simplier:
RTC_DATA_ATTR sensorsRecord newrecord{20, ID_sensor, ID_msg, epochUnion, ValueUnion, intValue, 30};
RTC_DATA_ATTR CircularBuffer<sensorsRecord, 50> test_SensorsDatas;
void test_RTC_memory2(){
newrecord.ID_msg.value++;
ID_msg.value++;
Serial.println(String(newrecord.ID_msg.value));
test_SensorsDatas.push(newrecord);
Serial.println("buffer size: " + String(test_SensorsDatas.size()));
But still not working, the ID_msg is incrementing well but not the buffer size even if I push a new value at every wake up.
Any suggestion?
