I want to blink a led using assembly language and arduino I want the circuit to have a normal state of 5 hz blinking frequency Then use two push buttons to increase or decrease the blinking frequency The up button will increment the blinking frequency by 5 hz step until the led seems to be continuously on While the down button will decrement the blinking frequency by 5 hz step until the normal state again Is this achievable ? And if any one can point me where to start as this the first time i am using assembly language but i am familiar with arduino
Here is one example of how to blink an LED in assembly coding on an Arduino UNO. You can attempt to solve your challenge. If you are stuck, please post the code and the connections and I am sure, you will get help again.
The code is here
#define __SFR_OFFSET 0
#include "avr/io.h"
.global main
main:
sbi DDRB, 5 ; Set PB5 as output
blink:
sbi PINB, 5 ; Toggle PINB
ldi r25, hi8(1000)
ldi r24, lo8(1000)
call delay_ms
jmp blink
delay_ms:
; Delay about (r25:r24)*ms. Clobbers r30, and r31.
; One millisecond is about 16000 cycles at 16MHz.
; The inner loop takes 4 cycles, so we repeat it 3000 times
ldi r31, hi8(4000)
ldi r30, lo8(4000)
1:
sbiw r30, 1
brne 1b
sbiw r24, 1
brne delay_ms
ret
Link to the project: https://wokwi.com/arduino/projects/290348681199092237
- 1,079
- 7
- 11
