I am trying to read potential meter data from Arduino using python, with the program on Arduino as follows :
#include <cvzone.h>
SerialData serialData; int sendVals[2];
void setup() { serialData.begin(9600); }
void loop() { int potVal = analogRead(A0); sendVals[0]= potVal; serialData.Send(sendVals); }
the program on the arduino side is running fine
and program in python as follows
from cvzone.SerialModule import SerialObject
arduino = SerialObject("COM7")
while True: data = arduino.getData() print(data[0])
but I get this error:
  File "C:...\site-packages\cvzone\SerialModule.py", line 68, in getData
    data = data.decode("utf-8")
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xf7 in position 0: invalid start byte
How to solve it?
Greenonline
  • 3,152
  • 36
  • 48
I would embed the call to .getData() into a try block and handle this specific exception with except UnicodeDecodeError. There can always be a transmission error, especially when the script is started.
However, I would do it differently:
  Serial.println(analogRead(A0));
...and on the python side use serial.readline() from pyserial instead. But I don't know cvzone and you might have a reason to use this instead of the commonly used pyserial.
Sim Son
  • 1,878
There seems that there may be an issue with the implementation of getData() in SerialModule.py.
From line 62
    def getData(self):
        :param numOfVals: number of vals to retrieve
        :return: list of data received
        data = self.ser.readline()
        data = data.split('#')
        dataList = []
        [dataList.append(d) for d in data]
        return dataList[:-1]
The block of code containing the readLine() should probably be with in a try...except block, like so:
    def getData(self):
        try:
            dataList = []
        except Exception as e:
            print(e)
            self.ser.close
An issue has been raised on Github: SerialModule.py - readLine() should be within try block. #49
Greenonline
  • 3,152
  • 36
  • 48
