I want to connect an ESP32 to a SMA Sunny Boy SB5000-TL Solar convertor over Bluetooth, but I cannot establish a connection and I'm kind of stuck. I use the internal bluetooth module of the ESP32.
What I've done:
  • I started with this project: https://github.com/delhatch/ESP32_to_SMA but I did not get past the connection. I tried to locate the problem area:
  • I tried using an Android app (Oxley Solar) to connect to the SB5000-TL Solar convertor, and that works great. The pin code of the convertor is set to 0000.
  • I tried using two ESP32 modules, one as master, one as slave and that works as well, though I do not need to set a pin. So the bluetooth module of my ESP32 works properly.
So the problem must be in my code, I guess.
This is the code I use to connect to the convertor:
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED) #error Bluetooth is not enabled! Please run make menuconfig to and enable it #endif
BluetoothSerial SerialBT; boolean confirmRequestPending = true;
// uint8_t ESP32Slave[6] = {0x84, 0xCC, 0xA8, 0x2C, 0x70, 0x1E}; // Address of Slave. uint8_t SMA[6] = {0x00, 0x40, 0x65, 0x12, 0x4B, 0x3E}; // Address of my SMA inverter. const char *pin = "0000"; //<- standard pin
void setup() { Serial.begin(115200); SerialBT.enableSSP(); SerialBT.onConfirmRequest(BTConfirmRequestCallback); SerialBT.onAuthComplete(BTAuthCompleteCallback); SerialBT.begin("ESP32master", true); //Bluetooth device name SerialBT.register_callback(callback); SerialBT.setPin("0000"); Serial.println("Connecting..."); bool connected = SerialBT.connect(SMA); if (connected) { Serial.println("Connected!"); } else { Serial.println("NOT Connected!"); } delay(500); SerialBT.end(); Serial.println("Bye!"); }
void callback(esp_spp_cb_event_t event, esp_spp_cb_param_t *param) { Serial.print("Got event!"); Serial.println(event); }
void BTConfirmRequestCallback(uint32_t numVal) { confirmRequestPending = true; Serial.println(numVal); }
void BTAuthCompleteCallback(boolean success) { confirmRequestPending = false; if (success) { Serial.println("Pairing success!!"); } else { Serial.println("Pairing failed, rejected by user!!"); } }
This is the result in the Serial console:
Connecting...
Got event!0
Got event!8
NOT Connected!
Got event!1
Bye!
I tried to replace the Mac Address with the name of the Convertor, I tried with and without pin.
I'm kind of stuck. Any idea's of how I can check what is wrong?
Is there any kind of scanner I can use to see what is happening with the app that works and what is (not) happening with my code?
Other ways to get more info/leads?
Could I use a Bluetooth sniffer or so (no experience) to find out what happens?
Any advice would be greatly appreciated!
mvermand
  • 427
