I am looking for a working example of an ESP32 sending telemetry data to Azure IoT hub. I find nothing working around the internet: below is the code I am trying to make it working.
As you can see in the logs, after a successful connection to the WiFi, followed by a successful connection to IoT Hub, the message has been accepted by the drive, but it is never sent successfully: Sound kinda timeout.
I posted the full Arduino SW for you to try.
[UPDATE] You need to install the ESP32MQQTClient lib from Microsoft that you'll find right there: https://platformio.org/lib/show/5462/ESP32%20Azure%20IoT%20Arduino
Bottom note: IoT Hub is fully configured and working, and device is provisioned and the connection string is OK.
And the logs are as follows:
11:36:50.573 -> mode:DIO, clock div:1
11:36:50.573 -> load:0x3fff0018,len:4
11:36:50.573 -> load:0x3fff001c,len:1216
11:36:50.609 -> ho 0 tail 12 room 4
11:36:50.609 -> load:0x40078000,len:10944
11:36:50.609 -> load:0x40080400,len:6388
11:36:50.609 -> entry 0x400806b4
11:36:50.881 -> ============ Starting connecting WiFi.
11:36:51.513 -> ......
11:36:54.011 -> ============ WiFi connected
11:36:54.011 -> IP address:
11:36:54.011 -> 192.168.1.20
11:36:54.011 -> Info: Initializing SNTP
11:36:54.999 -> Info: SNTP initialization complete
11:36:54.999 -> Info: IoT Hub SDK for C, version 1.1.23
11:36:58.050 -> Info: >>>Connection status: connected
11:36:58.050 -> ============ start sending events. 11:36:58.083 -> Info: >>>IoTHubClient_LL_SendEventAsync accepted message for transmission to IoT Hub.
11:37:08.066 -> Error: Time:Fri Nov 19 10:37:08 2021 File:/Users/stephanedeluca/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/AzureIoT/src/Esp32MQTTClient.cpp Func:SendEventOnce Line:316 Waiting for send confirmation, time is up 10006
11:37:08.099 -> Info: >>>Re-connect.
11:37:08.099 -> Error: Time:Fri Nov 19 10:37:08 2021 File:/Users/stephanedeluca/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/AzureIoT/src/az_iot/c-utility/pal/src/tlsio_openssl_compact.c Func:tlsio_openssl_destroy Line:213 tlsio_openssl_destroy called while not in TLSIO_STATE_CLOSED.
11:37:08.136 -> Info: >>>Confirmation[0] received for message tracking id = 0 with result = IOTHUB_CLIENT_CONFIRMATION_BECAUSE_DESTROY
11:37:08.136 -> Info: Initializing SNTP
11:37:09.109 -> Info: SNTP initialization complete
11:37:09.109 -> Info: IoT Hub SDK for C, version 1.1.23
11:37:09.470 -> Info: >>>IoTHubClient_LL_SendEventAsync accepted message for transmission to IoT Hub.
11:37:10.911 -> Info: >>>Connection status: connected
11:37:18.134 -> Error: Time:Fri Nov 19 10:37:18 2021 File:/Users/stephanedeluca/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/AzureIoT/src/Esp32MQTTClient.cpp Func:SendEventOnce Line:316 Waiting for send confirmation, time is up 10049
11:37:18.134 -> xxxxxxxxxxxx Failure sendind data: {"batteries":{"0":{"current": 1234.5}}}...
#include <WiFi.h>
#include "Esp32MQTTClient.h"
// Please input the SSID and password of WiFi
const char* ssid     = "XXX";
const char* password = "XXX";
/*String containing Hostname, Device Id & Device Key in the format:                         */
/*  "HostName=<host_name>;DeviceId=<device_id>;SharedAccessKey=<device_key>"                */
/*  "HostName=<host_name>;DeviceId=<device_id>;SharedAccessSignature=<device_sas_token>"    */
static const char* connectionString = "XXX";
static bool hasIoTHub = false;
  Serial.begin(115200);
  Serial.println("============ Starting connecting WiFi.");
  delay(10);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("\n============ WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
  if (!Esp32MQTTClient_Init((const uint8_t*)connectionString))
    hasIoTHub = false;
    Serial.println("============ Initializing IoT hub failed.");
    return;
  hasIoTHub = true;
  Serial.println("============ start sending events.");
  if (hasIoTHub)
    char buff[128];
    // replace the following line with your data sent to Azure IoTHub
    snprintf(buff, 128, "{\"batteries\":{\"0\":{\"current\": 1234.5}}}");
    if (Esp32MQTTClient_SendEvent(buff))
      Serial.println("============ Sending data succeeded");
    else
      Serial.printf ("xxxxxxxxxxxx Failure sendind data: %s...", buff); Serial.println();
    delay(5000);
