I try to run an atmega328p as a i2c slave. even with the bare minimum the slave acts as its not wired at all: NACK is transmitted after request (see logic analyzer).
The master should read a constant value in this example. iam using the wire.h lib. pullup resistors on SDA, SCL 4.7kOhm.
master.ino: esp8266 (working, sends requests)
#include <Wire.h>
#define DEFAULT_SLAVE_ADDRESS 0x0A
void setup()
  Wire.begin(); // join i2c bus as master
  Serial.begin(9600);
  Serial.println("\n Hello");
  delay(2000);
void loop()
  //Wire.beginTransmission(DEFAULT_SLAVE_ADDRESS);
  //Wire.write(0);
  //Wire.endTransmission();
  //delay(10);
  Wire.requestFrom(DEFAULT_SLAVE_ADDRESS, 1);
  Serial.println(Wire.read());
  delay(1000);
slave.ino: atmega328p
#include <Wire.h>
#define F_CPU 8000000UL
volatile uint8_t nr;
void setup()
  Wire.begin(0x0A);                // join i2c bus with address #4
  //Wire.onReceive(receiveEvent); // register event
  Wire.onRequest(requestEvent);
void loop()
//void receiveEvent(int howMany)
//  while(0 < Wire.available()) // loop through all but the last
//  int x = Wire.read();    // receive byte as an integer
void requestEvent()
  nr = 99;
  Wire.write(nr);
Serial output from master: (got no val)
Logic analizer output: nack
Wiring on atmega: VALUE-PIN
  • VCC 7
  • GND 8
  • SCL 28
  • SDA 27
anyone got an idea whats missing?
Edit: removed receiveEvent(), added CPU speed and it worked
micro_
