My Arduino Pro Micro can source 500mA from 3.3V VCC, when it is USB powered.
The chip itself, is rated for 200mA, though, and its output pins for 20mA recommended, 40mA max.
I am looking to have 3 PWM outputs, though, each doing 120mA. The combined 360mA would be in-spec for VCC, but not for the chip.
Is there a buffer IC that I can use that will switch these loads at that current, and can keep up with a few hundred Hz PWM?
From what I've read, you can switch loads with discrete transistors, but these require extra components like resistors? Are there CMOS chips that will take the PWM signal and output it at 120mA?
I am looking to source the current, not sink it.
The load in my application are LEDs driven with constant-current drivers that are daisy chained. I just want to PWM the Vled supply so I can dim per channel, of the entire daisy chain.
UPDATE: I went with @Majenko's solution of pre-biased DTB114EK. Although it somewhat works, it seems to struggle to deliver 30mA out, even though it is rated at 500mA?
UPDATE: The DTB113ZC works better. Due to a lower bias resistor, I can get more current through it.
