I'm currently facing an issue using delay() and millis() functions in an external cpp file. The issue is that when I used delay() in my main program (meaning .ino file) it works well but when I call the same function in an external cpp file, I'm stuck in the delay function. Concerning the setup, the .hpp linked to the used cpp is well included in the .ino file and the librairy Arduino.h is included in my cpp. I also tried to replace delay by a loop using millis but the value returned by millis is always 0. I'm using an Arduino mega2560 and a water level sensor in the follwing example. The Arduino IDE version is 1.8.16.
Here is an extract from my ino file:
#include <Arduino.h>
#include "DS3231.h"
#include "MyGardenClock.hpp"
#include "sensors.hpp"
#include <LiquidCrystal.h>
#include "Keypad.h"
#include <Wire.h>
///Time object creation
DS3231 clock; //Clock object -> contains basic Real Time Clock functions
RTCDateTime dt; //Struct from DS3231 lib - contains date and time
mG_RTC myClock; //Object that contains specific clock functions to my project like printing date and time on the lcd...
///LCD object creation
//--Pin allocation
const int rs = 2, en = 1, d4 = 4, d5 = 7, d6 = 8, d7 = 10;
//--LCD dynamic object creation
LiquidCrystal* pLCD = new LiquidCrystal(rs, en, d4, d5, d6, d7);
///Keypad parametrization and object creation
//Define col nb and row nb
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'','0','#','D'}
byte rowPins[ROWS] = {52, 50, 48, 46}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {44, 42, 40, 38}; //connect to the column pinouts of the keypad
//Keypad dynamic object creation
Keypad pKpd = new Keypad(makeKeymap(hexaKeys),rowPins,colPins,ROWS,COLS);
///Sensors object creation
//WaterLvl Sensors
//--Pin allocation
const int WtrLvlAnalogPin = 8; //pin used to read value from water lvl sensor
const int WtrLvlPowerPin = 35; //pin used to power the sensor before reading a value
//--WaterLvl dynamic object creation
Water_Lvl_Sensor* pWtrLvlSens = new Water_Lvl_Sensor(WtrLvlAnalogPin,WtrLvlPowerPin); //contains the delay and millis functions that don't work
/////////// TEST FUNCTIONS ///////////
void testLCD_Kpd(Keypad,LiquidCrystal); //test lcd and keypad
void testWtrLvlSens(Water_Lvl_Sensor,LiquidCrystal); //test water lvl sensor
void setup()
Serial.begin(9600);
pLCD->begin(16,2);
testLCD_Kpd(pKpd,pLCD);
testWtrLvlSens(pWtrLvlSens,pLCD);
void loop()
////////////////////// TEST FUNCTIONS ///////////////////////////
void testLCD_Kpd(Keypad* pKpd, LiquidCrystal* pLCD)
char test;
test ='i';
pLCD->print("Hello");
do
test = pKpd->waitForKey();
}while(test=='i');
pLCD->clear();
delay(3000); //This one work well
pLCD->print("test = ");
pLCD->print(test);
void testWtrLvlSens(Water_Lvl_Sensor* pWLS,LiquidCrystal* plcd)
int wtrLvl;
wtrLvl = pWLS->getCurrentWaterLvlValue();
plcd->setCursor(0,1);
plcd->print("wtrLvl = ");
plcd->print(wtrLvl);
Here is an extract from my cpp file:
- CLASS WATER LvL SENSOR DESCRIPTION *
///Constructor
//-- Assign pin number (analog & digital)
//-- Define pinMode for VCC + set to low
//-- read and store actual waterLevelValue as initial val
Water_Lvl_Sensor::Water_Lvl_Sensor(int anPinNb, int DigPinNb)
//Variable used for millis
unsigned long prevTime;
unsigned long currentTime;
const unsigned long delayTime = 100;
Serial.begin(9600); //to debug
//Assign analog and digital pin numbers
analogPinNumber = anPinNb;
VCC_digitalPinNumber = DigPinNb;
pinMode(VCC_digitalPinNumber, OUTPUT); //Digital pin to power the sensor
digitalWrite(VCC_digitalPinNumber,HIGH);//Turn sensor ON before reading initial value
//delay(100); //not working ???
prevTime = millis(); //get and store actual time
do
currentTime = millis(); //get actual time
Serial.println(currentTime); //print actual time (debug only)
}while(currentTime<(prevTime+delayTime)); //while time spent < 100
currentValue = analogRead(analogPinNumber); //read analog value
digitalWrite(VCC_digitalPinNumber,LOW); //turn sensor OFF
historyValue = currentValue; //init history val
minValue = 0; //default value - sensor dry
maxValue = 520; //default value - sensor under water
Does anyone has a solution?
I hope I've given enough details. If not, please feel free to ask.
Thanks!
