My sketch below is simply using a touch sensor to activate a servo motor to go from from initial position 0 to 180 then back to 0. then I want the Adruino NANO to go to sleep to conserve some battery life.
Being a novice to programing and after many attempts to use his code and intergrade it with mine. Was unsuccessful.
so if anyone can help intergrade the gammon's sketch below into mine it would be greatly appreciated. As I'm out of ideas.
HERE IS MY SKETCH
#include <Servo.h>
// constants won't change const int SENSOR = 2; // Arduino pin connected to motion sensor's pin 7 const int SERVO = 9; // Arduino pin connected to servo motor's pin 9
Servo servo; // create servo object to control a servo
int pos = 0; // variable to store the servo position
// variables will change: int lastMotionState; // the previous state of motion sensor int currentMotionState; // the current state of motion sensor
Serial.begin(9600); // initialize serial pinMode(SENSOR, INPUT); // set arduino pin 9 to input mode servo.attach(SERVO); // attaches the servo on pin 12 to the servo object
servo.write(0); currentMotionState = digitalRead(SENSOR); }
void loop() { lastMotionState = currentMotionState; // save the last state currentMotionState = digitalRead(SENSOR); // read new state
if (currentMotionState == LOW && lastMotionState == HIGH) { // pin state change: LOW -> HIGH Serial.println("OFF"); servo.write(0); delay(100); // waits (X)ms for the servo to reach the position } else if (currentMotionState == HIGH && lastMotionState == LOW) { // pin state change: HIGH -> LOW Serial.println("ACTIVE"); servo.write(180); delay(2000); // waits (x)ms for the servo to reach the position } delay(10); // repeats program - larger delay - trigger is }
______________________________________
Author:Ab Kurk SLEEP SKETCH
This sketch is part of the beginners guide to putting your Arduino to sleep tutorial. It is to demonstrate how to put your arduino into deep sleep and how to wake it up.
#include <avr/sleep.h>//this AVR library contains the methods that controls the sleep modes
#define interruptPin 2 //Pin we are going to use to wake up the Arduino
void setup() { Serial.begin(115200);//Start Serial Comunication pinMode(LED_BUILTIN,OUTPUT);//We use the led on pin 13 to indecate when Arduino is A sleep pinMode(interruptPin,INPUT_PULLUP);//Set pin d2 to input using the buildin pullup resistor digitalWrite(LED_BUILTIN,HIGH);//turning LED on }
void loop() { delay(5000);//wait 5 seconds before going to sleep Going_To_Sleep(); }
void Going_To_Sleep(){ sleep_enable();//Enabling sleep mode attachInterrupt(0, wakeUp, LOW);//attaching a interrupt to pin d2 set_sleep_mode(SLEEP_MODE_PWR_DOWN);//Setting the sleep mode, in our case full sleep digitalWrite(LED_BUILTIN,LOW);//turning LED off delay(1000); //wait a second to allow the led to be turned off before going to sleep sleep_cpu();//activating sleep mode Serial.println("just woke up!");//next line of code executed after the interrupt digitalWrite(LED_BUILTIN,HIGH);//turning LED on }
void wakeUp(){ Serial.println("Interrrupt Fired");//Print message to serial monitor sleep_disable();//Disable sleep mode
detachInterrupt(0); //Removes the interrupt from pin 2;
jsotola
  • 1,554
Anthony
I'm going to guess that you are doing something like a door or safe lock, which may occasionally be used to activate a motor to unlock something but 99.99% of the time is sitting there doing nothing, and you want to save power in that time.
You need to rework somewhat.
  • An interrupt to detect a switch press. Then the processor can sleep, using very little power.
  • The interrupt, when it happens, wakes the processor
  • You activate the motor to unlock the door or whatever-it-is.
  • You put the processor into low power mode, and go back to sleep
Since my name was mentioned in the question, tips for doing low-power stuff are at this link. And here for stuff about interrupts.
Plus a slightly abridged version (due to space limitations) here on this site.
(You aren't supposed to make answers where the answer is totally in the link, but in this case the link is just supplementary material)
Nick Gammon
  • 38,901
