i'm trying to play a passive buzzer with an IR reciver
My Code
#include <IRremote.h> IRrecv irrecv(10); decode_results results;
void setup() { // put your setup code here, to run once: Serial.begin(9600); pinMode(11, OUTPUT);//buzzer irrecv.enableIRIn();//Ir reciver at pin 10 }
int cmdex = 0;
void loop() { // put your main code here, to run repeatedly:
if(irrecv.decode(&results)){ cmdex = 1; Serial.println(results.value); unsigned long data = results.value; switch(data){ case 0xFF30CF: noTone(11); tone(11, 1056); break; case 0xFF18E7: noTone(11); tone(11, 571); break; case 0xFF6897: noTone(11); break; } irrecv.resume(); } }
Issue
My problem is that if i use any button instead of 1 (FF30CF) 0 (FF6897) or 2 (FF18E7) the serilal port give me the right data, then when i pusch 1 the buzzer starts to play but when i push another button, the data keep changing at every push.
Serial Output FF10EF (here I push 4)
FF38C7 (here I push 5)
FF5AA5 (here I push 6)
FF30CF (here I finally push 1 and the buzzer starts to play)
(then I push 3 times 0, but the output is different from the expected FF6897 and the buzzer doesn't stop)
D965AA42
EB670632
AB03A967
Note
  • I'm using the IRremote.h library
