10
I just migrated to a new computer running on an M1 CPU (the new Apple Silicon, arm64 based). I've been searching for CH34x drivers for my TTGO-Lora32 board, but can't find any around, nor can I find mentions of them existing or not. The x86_64 driver installs, but obviously can't run due to it being an incompatible architecture.
Thus, is it currently possible to use a CH34x based board on an M1 Mac?
finitud
  • 250
So they pushed a new version to GitHub late september:
https://github.com/WCHSoftGroup/ch34xser_macos
This should be the maintained version ahead of what they offer as a download on the official website.
Common other issues:
  • When reinstalling, make sure to first remove all old files:
sudo rm –rf /var/db/receipts/*CH34xVCPDriver*.*
sudo rm -rf /Library/Extensions/CH34xVCPDriver.kext
also don't forget to check for any related files in /dev/ and the .app file in your applications folder if these already exist.
  • Restart the device before reinstalling.
  • Restart the device after installation.
  • Try a different USB-Cable / USB-Hub.
Note: steps listed here were reportedly solutions I came across during my research which worked for other people and my colleagues. For me it still doesn't work; but I am using a lot of unstable builds for my OS and other software that might interfere.
Update February 2022: Now with Monterey out of closed Beta this works like a charm for me. At least for the Web IDE.
Cerealz
  • 71
After hours of mindless reinstalling of the drivers on M1, reboots and other magic tricks, I almost decided to switch to windows to make my arduino ide work. My NodeMCU board with CH340G would either show up as a serial port or not.
So I leave this message here as clearly many people struggling with M1 end up on this page: buy good microUSB cable. And I mean a good one. All problems disappeared right away. I had three cables at home but none was working - clearly most are only good for charging the phone, but suck at data transfer.
Marek
  • 61
As it turns out, I found in the following post:
https://github.com/LilyGO/LILYGO-T-OI/issues/3#issuecomment-907645945
a link to a particular build of the CH340 drivers that is properly signed and can be installed on the M1 mac with no troubles.
finitud
  • 250
Worth the try. The .pkg file from here worked in my High Sierra. I've turned-on the "csrutil enable" before install, and it still worked...:
