I have a code for finding the rpm of one system calling here as engine , the engine have a hall sensor output and I have tried the following Code
#define SERVO_MIN 2000
#define SERVO_MAX 4000
struct Pulse {
uint32_t last_toggle;
uint32_t width;
uint32_t width_prev;
uint32_t time_prev;
bool stateHigh = false;
uint32_t get_width() {
noInterrupts();
uint32_t width_copy = width;
interrupts();
return width_copy;
struct Engine {
uint16_t servoMin = 2000, servoMax = 4000;
uint16_t rpm_desired;
volatile Pulse pulse;
uint32_t get_rpm() {
cli();
uint32_t rpm_width = pulse.get_width();
sei();
return 12e7 / rpm_width;
Engine engine1,engine2;
void pin_initialization() {
// INT2
pinMode(19, INPUT_PULLUP);
// Input capture points
pinMode(49, INPUT_PULLUP);
pinMode(48, INPUT_PULLUP);
void timer4_initialization() {
cli();
TCCR4A = 0; TCCR4B = 0; TCCR4C = 0;
TCCR4A = B10101011;
TIMSK4 = B00100000;
TIFR4 = _BV(ICF4);
TCCR4B = B11011010;
OCR4A = 39999;
OCR4B = SERVO_MIN;//7
OCR4C = SERVO_MIN;//8
sei();
void timer5_initialization() {
cli();
TCCR5A = 0; TCCR5B = 0; TCCR5C = 0;
TCCR5A = B10101011;
TIMSK5 = B00100000;
TIFR5 = _BV(ICF5);
TCCR5B = B11011010;
OCR5A = 39999;
OCR5B = SERVO_MIN;//45
OCR5C = SERVO_MIN;//44
sei();
void timer3_initialization() {
TCCR3A = 0x00; TCCR3C = 0x00;
TCNT3 = 0x1FF; // from datasheet
TIFR3 = _BV(TOV3);
TIMSK3 = _BV(TOIE3); // overflow enable
TCCR3B = B00000010; // 8 prescaling
volatile uint32_t ovfCount = 0;
ISR(TIMER3_OVF_vect) {
ovfCount++;
void pulseWidthCalculator(Pulse *channel) {
unsigned char sreg;
sreg = SREG;
cli();
uint16_t tcnt3 = TCNT3;
uint32_t ovf_count = ovfCount;
SREG = sreg;
if (bit_is_set(TIFR3, TOV3) && tcnt3 < 16384) {
ovf_count++;
uint32_t time = ovf_count << 16 | tcnt3;
if (!channel->stateHigh) {
channel->stateHigh = true;
} else if ( channel->stateHigh) {
channel->width = time - channel->last_toggle;
channel->stateHigh = false;
channel->last_toggle = time;
sei();
void externalInterrputInitialization() {
EIFR = _BV(INTF2) ;
EICRA = 0; EICRB = 0;
EICRA = B00100000;
EIMSK = B00000100;
ISR(INT2_vect) {
pulseWidthCalculator(&engine1.pulse);
ISR(TIMER4_CAPT_vect) {
pulseWidthCalculator(&engine2.pulse);
ISR(TIMER5_CAPT_vect) {
// pulseWidthCalculator(&engine2.pulse);
Serial.begin(115200);
pin_initialization();
delayMicroseconds(10);
externalInterrputInitialization();
timer3_initialization();
timer4_initialization();
timer5_initialization();
Serial.print(engine1.get_rpm());
Serial.print("\t" );
Serial.println(engine2.get_rpm());
The same hall sensor output is given to the INT2 (pin #19) pin and ICP4(pin #49) and the results obtained is given below
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
24590 1626
1658 1626
1658 1626
1658 1626
1658 1626
1658 1626
1658 1626
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
1658 1646
4577 1646
4577 1646
4577 1646
4577 1646
4577 1646
4577 1646
4577 1646
1667 1581
1667 1581
1667 1581
1667 1581
1667 1581
1667 1581
1667 1581
1667 1581
1667 1581
1667 1581
1667 1581
1667 1581
1667 1581
1667 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
2029 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1581
3428571 1546
3428571 1546
3428571 1546
3428571 1546
3428571 1546
3428571 1546
3428571 1546
3428571 1546
3428571 1546
3428571 1546
3054 1565
3054 1565
3054 1565
3054 1565
3054 1565
3054 1565
3054 1565
3054 1565
3054 1565
3054 1565
3054 1565
3054 1565
3054 1565
3054 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
2961 1565
4615384 1565
4615384 1565
4615384 1565
4615384 1565
4615384 1565
4615384 1565
4615384 1565
4615384 1565
4615384 1565
4615384 1565
4615384 1565
4615384 1565
4615384 1565
3792 1565
3792 1565
3792 1565
3792 1565
3792 1565
3792 1565
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
3792 1587
1542 1587
1542 1587
1542 1587
1542 1587
1542 1587
1542 1587
1542 1587
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1542 1521
1710 1521
1710 1521
1710 1521
1710 1521
1710 1521
1710 1521
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
1710 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3062 1619
3361 1619
3361 1619
3361 1619
3361 1619
3361 1619
3361 1619
3361 1619
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
3361 1581
1449 1581
1449 1581
1449 1581
1449 1581
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
1449 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1541
2166 1628
2166 1628
2166 1628
2166 1628
2166 1628
2166 1628
2166 1628
2166 1628
2166 1628
2166 1628
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
9880 1544
1588 1544
1588 1544
1588 1544
1588 1544
1588 1544
1588 1544
1588 1544
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1588 1586
1693 1586
1693 1586
1693 1586
1693 1586
1693 1586
1693 1586
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1693 1599
1584 1599
1584 1599
1584 1599
1584 1599
1584 1599
1584 1599
1584 1599
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1584 1567
1526 1567
1526 1567
1526 1567
1526 1567
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1526 1646
1693 1646
1693 1646
1693 1646
1693 1646
1693 1646
1693 1646
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
1693 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1682
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
2464 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
1699 1623
3947 1623
3947 1623
3947 1623
3947 1623
3947 1623
3947 1623
3947 1623
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
3947 1688
1537 1688
1537 1688
1537 1688
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1537 1655
1709 1655
1709 1655
1709 1655
1709 1655
1709 1655
1709 1655
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
1709 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
61696 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
83449 1699
I have a feeling that the Noise canceller in the input capture pin is helping here, I would like to get help on
- How to make the interrupt values also correct
- What logical mistake am I making.
how to add the logic of noise cancelling to Interrupt subroutine code.
If I have to add 4/6 such engines what is the best option.
** with a function generator both INT and ICP are giving the correct result.
