I'm trying to compile my code but i keep exceeding my global variable memory by 12%. Is there anything i can do in my code to further reduce RAM usage? Or do i have to do modifications to the libraries I'm using? Here is my main program:
    #include <MIDI.h>
#include <FastLED.h>
#include <SoftwareSerial.h>
#define LED_PIN 3 #define NUM_LEDS 60 #define LEDMAP 0xAB5AB5AB5AB5AB5 #define OFFSET 36 #define RANGECHECK if (pitch > 35 && pitch < 96)
SoftwareSerial softSerial(2, 4); CRGB leds[NUM_LEDS];
MIDI_CREATE_INSTANCE(SoftwareSerial, softSerial, midiB);
void setup() { FastLED.addLeds<WS2811, LED_PIN, GRB>(leds, NUM_LEDS); FastLED.clear(true); midiB.begin(MIDI_CHANNEL_OMNI); midiB.setHandleNoteOn(HandleOn); midiB.setHandleNoteOff(HandleOff); }
void loop() { midiB.read(); }
void HandleOn(byte channel, byte pitch, byte velocity) { RANGECHECK { leds[pitch - OFFSET] = bitRead(LEDMAP, (pitch - OFFSET)) ? CRGB::NavajoWhite : CRGB::Salmon; FastLED.show(); } }
void HandleOff(byte channel, byte pitch, byte velocity) { RANGECHECK { leds[pitch - OFFSET] = CRGB::Black; FastLED.show(); } }
I've reached my limit in optimizing my RAM usage here. Any suggestions for optimizing my code would be appreciated.
Boyfinn
  • 245
FastLED needs to keep the colors of all the pixel in RAM, so that is using a lot of RAM.
To get around this, you could use a strategy that generates the pixel data on the fly as you send it out to the strings. Here is an example of a project that does that...
https://wp.josh.com/2021/04/21/build-a-live-scrolling-tickertape/
Also, SoftSerial keeps a buffer (looks like 64 bytes?) which also uses some RAM. You could use a different approach to serial communications that does not allocate such a large buffer. It would take work, but you could even process the midi bytes as they were received and not need any byte buffer.
bigjosh
  • 1,593
Since i don't use sysex messages, i got my RAM usage down to 84% by setting the SysExMaxSize
in midi_settings.h to 0.
Boyfinn
  • 245
