I am using Arduino mega with 4 interrupts to find the rotation speed of 4 motors . For this I have used INT2, INT3, INT4, INT5 and the code for the same is given below
struct Pulse {
uint32_t last_toggle;
uint32_t width;
bool stateHigh;
uint32_t get_width() {
noInterrupts();
uint32_t width_copy = width;
interrupts();
return width_copy;
Pulse ch1, ch2, ch3, ch4;
void pin_initialization() {
// Four engine configuration
pinMode(19, INPUT_PULLUP);
pinMode(18, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
volatile uint32_t ovfCount = 0;
ISR(TIMER3_OVF_vect) {
ovfCount++;
void timer3_initialization() {
TCCR3A = 0x00;
TCNT3 = 0x1FF; // from datasheet
TIFR3 = _BV(TOV3);
TIMSK3 = _BV(TOIE3); // overflow enable
TCCR3B = B00000011; // 64 prescaling
void pulseWidthCalculator(Pulse *channel){
unsigned char sreg;
sreg = SREG;
cli();
uint16_t tcnt3 = TCNT3;
SREG = sreg;
uint32_t ovf_count = ovfCount;
if (bit_is_set(TIFR3, TOV3) && tcnt3 < 32768) {
ovf_count++;
uint32_t time = ovf_count << 16 | tcnt3;
if (!channel->stateHigh) { // first high
channel->stateHigh = true;
} else if ( channel->stateHigh) { // second High
channel->width = time - channel->last_toggle;
channel->stateHigh = false;
channel->last_toggle = time;
ISR(INT2_vect) {
pulseWidthCalculator(&ch1);
ISR(INT3_vect) {
pulseWidthCalculator(&ch2);
ISR(INT4_vect) {
pulseWidthCalculator(&ch3);
ISR(INT5_vect) {
pulseWidthCalculator(&ch4);
void externalInterrputInitialization() {
EIFR = _BV(INTF2) | _BV(INTF3) | _BV(INTF4) | _BV(INTF5);
EICRA = 0; EICRB = 0;
EICRA = B10100000;
EICRB = B00001010;
EIMSK = B00111100;
Serial.begin(115200);
pin_initialization();
delayMicroseconds(10);
externalInterrputInitialization();
timer3_initialization();
String a = String(15e6/ch1.get_width());
a += " ";
a += String(15e6/ch2.get_width());
a += " ";
a += String(15e6/ch3.get_width());
a += " ";
a += String(15e6/ch4.get_width());
Serial.println(a);
The issue I am facing is , whenever I give a signal to INT2, INT3 is also getting triggered, same with INT4, INT5 also getting triggered without signal .
What I am I missing here, ?
Should I make my channels ch1, ch2 , ch3, ch4 to volatile or not.? like
volatile Pulse ch1, ch2, ch3, ch4
- Any thing wrong with
OUTPUT_PULLUP
