1)The values drifts to the extreme every time I run this , I guess this is due to my mistake in the calculation of angles or in the filter that I have applied which I have been trying to but can't find it. 2)I have tried to calibrate MPU many times but failed as the x-axis value is showing 0 only when I tilt the bot to 12-14 degrees on x-axis(data from only accelometer),(if you can just tell me the variable to modify)
#include <Wire.h>
long accelX, accelY, accelZ;
float gForceX, gForceY, gForceZ,elapsedTime;
long gyroX, gyroY, gyroZ;
float rotX, rotY, rotZ;
double x,y,z,dx,dy,dz,ex,ey,ez,desx=0,desy=0,desz=0;
float PID, PWM, error, previous_error,timePrev,time1;
float pid_p;
float pid_i;
float pid_d;
float rad_to_deg = 180/3.141592654;
/////////////////PID CONSTANTS/////////////////
double kp=2;
double ki=0;
double kd=0;
int motor1pin1 = 2;
int motor1pin2 = 3;
int led = 9;           // the PWM pin the LED is attached to
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;
void setup() { Serial.begin(115200); Wire.begin(); pinMode(motor1pin1, OUTPUT); pinMode(motor1pin2, OUTPUT); pinMode(9, OUTPUT); pinMode(13, OUTPUT); setupMPU(); delay(500); }
void loop() { timePrev = time1; // the previous time is stored before the actual time read time1 = millis(); // actual time read/ elapsedTime = (time1 - timePrev) / 1000; recordAccelRegisters(); recordGyroRegisters(); processangle(); Apply_PID(); printData(); delay(100); } void right(int PWM) { analogWrite(9, PWM); digitalWrite(motor1pin1, HIGH); digitalWrite(motor1pin2, LOW); digitalWrite(13, HIGH); Serial.println("RIGHT"); } void left(int PWM) { analogWrite(9, PWM); digitalWrite(motor1pin1, LOW); digitalWrite(motor1pin2, HIGH); Serial.println("LEFT"); } void stopper() { analogWrite(9, PWM); digitalWrite(motor1pin1, LOW); digitalWrite(motor1pin2, HIGH); Serial.println("STOPPED"); } void setupMPU() { Wire.beginTransmission(0b1101000); //This is the I2C address of the MPU (b1101000/b1101001 for AC0 low/high datasheet sec. 9.2) Wire.write(0x6B); //Accessing the register 6B - Power Management (Sec. 4.28) Wire.write(0b00000000); //Setting SLEEP register to 0. (Required; see Note on p. 9) Wire.endTransmission();
Wire.beginTransmission(0b1101000); //I2C address of the MPU Wire.write(0x1B); //Accessing the register 1B - Gyroscope Configuration (Sec. 4.4) Wire.write(0x00000000); //Setting the gyro to full scale +/- 250deg./s Wire.endTransmission(); Wire.beginTransmission(0b1101000); //I2C address of the MPU Wire.write(0x1C); //Accessing the register 1C - Acccelerometer Configuration (Sec. 4.5) Wire.write(0b00000000); //Setting the accel to +/- 2g Wire.endTransmission(); }
void recordAccelRegisters() { Wire.beginTransmission(0b1101000); //I2C address of the MPU Wire.write(0x3B); //Starting register for Accel Readings Wire.endTransmission(); Wire.requestFrom(0b1101000,6); //Request Accel Registers (3B - 40) while(Wire.available() < 6); accelX = Wire.read()<<8|Wire.read(); //Store first two bytes into accelX accelY = Wire.read()<<8|Wire.read(); //Store middle two bytes into accelY accelZ = Wire.read()<<8|Wire.read(); //Store last two bytes into accelZ processAccelData(); }
void processAccelData() { gForceX = accelX / 16384.0; gForceY = accelY / 16384.0; gForceZ = accelZ / 16384.0; x= (RAD_TO_DEG * (atan2(-gForceY, -gForceZ)+PI)); y= RAD_TO_DEG * (atan2(-gForceX, -gForceZ)+PI); z= RAD_TO_DEG * (atan(sqrt(square(-gForceY) + square(-gForceX)) / -gForceZ)); /* x=map(x,340,11,-90,90);*/
Serial.print(&quot; AccelX=&quot;);
Serial.print(x);
void recordGyroRegisters() { Wire.beginTransmission(0b1101000); //I2C address of the MPU Wire.write(0x43); //Starting register for Gyro Readings Wire.endTransmission(); Wire.requestFrom(0b1101000,6); //Request Gyro Registers (43 - 48) while(Wire.available() < 6); gyroX = Wire.read()<<8|Wire.read(); //Store first two bytes into accelX gyroY = Wire.read()<<8|Wire.read(); //Store middle two bytes into accelY gyroZ = Wire.read()<<8|Wire.read(); //Store last two bytes into accelZ processGyroData(); }
void processGyroData() { rotX = (gyroX / 131.0); rotY = gyroY / 131.0; rotZ = gyroZ / 131.0; Serial.print(" GyroX="); Serial.println(rotXelapsedTime); } void processangle() { dx=0.98 (dx + rotXelapsedTime) + 0.02x; dy=0.98 (dy + rotYelapsedTime) + 0.02y; dz=0.98 (dz + rotZelapsedTime) + 0.02z; ex=dx-desx; ey=dy-desy; ez=dz-desz; Serial.print("After Filter Angle"); Serial.println(ex); } void Apply_PID() { float l=(float)ex; pid_p=kpl; pid_i = pid_i+(kil);
pid_d = kd ((l - previous_error)/elapsedTime); PID = pid_p + pid_i + pid_d; /Serial.print("I="); Serial.println(pid_d); Serial.print("p="); Serial.println(pid_p);*/ Serial.print("PID"); Serial.println(PID);
if(l>5.5 || l<5.5) { if(l<0) right(PID); else left(PID); } else { stopper(); } previous_error = l; }
void printData() { /Serial.print("Gyro (deg)"); Serial.print(" X="); Serial.print(rotX); Serial.print(" Y="); Serial.print(rotY); Serial.print(" Z="); Serial.print(rotZ); Serial.print(" Accel (g)"); Serial.print(" X="); Serial.print(gForceX); Serial.print(" Y="); Serial.print(gForceY); Serial.print(" Z="); Serial.println(gForceZ);/ /* Serial.print(" PWM"); Serial.println(PID);*/ }
Aditya Raj
  • 43
