I am try to build this AC-DC meter, the code original used default A3 as input, how can change the input on A0? the link: https://simple-circuit.com/arduino-autoranging-ac-dc-voltmeter-with-trms/
Thanks for help Adam
* Arduino autoranging AC/DC voltmeter.
* Voltage and frequency are printed on 1602 LCD screen.
* This is a free software with NO WARRANTY - Use it at your own risk!
* https://simple-circuit.com/
#include <LiquidCrystal.h> // include Arduino LCD library // LCD module connections (RS, E, D4, D5, D6, D7) LiquidCrystal lcd(8, 9, 10, 11, 12, 13);
// define autoranging channel pins #define CH0 2 #define CH1 3 #define CH2 4 #define CH3 5
const uint16_t Time_Out = 50000, // time out in microseconds Periods = 10; // number of periods of measurement (for AC voltage only)
// variables byte ch_number; const uint16_t res_table[4] = {2444, 244, 94, 47}, // voltage divider resistances in tenths kOhms total_res = 22444; // total resistance in tenths kOhms uint16_t current_res; volatile byte per;
void setup(void) { pinMode(CH0, OUTPUT); pinMode(CH1, OUTPUT); pinMode(CH2, OUTPUT); pinMode(CH3, OUTPUT);
lcd.begin(16, 2); // set up the LCD's number of columns and rows lcd.setCursor(1, 0); lcd.print("Voltage:");
ch_number = 0; ch_select(ch_number);
// ADC and analog comparator configuration ADMUX = 0x03; ADCSRA = 0x87; ADCSRB = (0 << ACME); // select AIN1 as comparator negative input ACSR = 0x13; // turn on analog comparator
// analog comparator ISR ISR (ANALOG_COMP_vect) { byte count = 0; for(byte i = 0; i < 50; i++) { if ( ACSR & 0x20 ) count++; }
if(count > 48) per++; }
// main loop void loop() { bool dc_flag = 0; // DC voltage flag bit int32_t sum = 0; // sum of all readings uint16_t n = 0; // number of readings (samples)
ACSR = (1 << ACI); // clear analog comparator interrupt flag ACSR = (1 << ACIE); // enable analog comparator interrupt
uint32_t current_m = micros(); // save current millis byte current_per = per; // save current period number while ( (current_per == per) && (micros() - current_m < Time_Out) ) ;
if( micros() - current_m >= Time_Out ) { // if there's time out event ==> voltage signal is DC dc_flag = 1; for (byte i = 0; i < 200; i++) { ADCSRA |= 1 << ADSC; // start conversion while(ADCSRA & 0x40); // wait for conversion complete int16_t an = (int16_t)(ADCL | (uint16_t)ADCH << 8) - 511; sum += an; n++; // increment number of readings delay(1); } }
else { // here, voltage signal is AC current_m = micros(); // save current millis() per = 0; while ( (per < Periods) && (micros() - current_m < (uint32_t)Time_Out * Periods) ) { ADCSRA |= 1 << ADSC; // start conversion while(ADCSRA & 0x40); // wait for conversion complete int32_t an = (int16_t)(ADCL | (uint16_t)ADCH << 8) - 511; sum += sq(an); // sq: square n++; // increment number of readings } }
ACSR = (0 << ACIE); // disable analog comparator interrupt uint32_t total_time = micros() - current_m; // used to claculate frequency
// voltage calculation float v; if(dc_flag) // if voltage signal is DC v = (4 * sum)/n; // calculate Arduino analog channel DC voltage in milli-Volts
else // here voltage signal is AC v = 4 * sqrt(sum/n); // calculate Arduino analog channel RMS voltage in milli-Volts
// claculate actual (input) voltage in milli-Volts (apply voltage divider equation) v = v * (float)total_res/current_res; v /= 1000; // get voltage in Volts
uint16_t v_abs = abs(int16_t(v)); if( (v_abs >= 10 && ch_number == 0) || (v_abs >= 100 && ch_number == 1) || (v_abs >= 250 && ch_number == 2) ) { ch_number++; ch_select(ch_number); delay(10); return; }
if( (v_abs < 220 && ch_number == 3) || (v_abs < 80 && ch_number == 2) || (v_abs < 8 && ch_number == 1) ) { ch_number--; ch_select(ch_number); delay(10); return; }
char _buffer[8]; lcd.setCursor(0, 1); if( v < 0) lcd.print('-'); else lcd.print(' '); if(v_abs < 10) sprintf( _buffer, "%01u.%02u", v_abs, abs((int16_t)(v * 100)) % 100 ); else if( v_abs < 100) sprintf( _buffer, "%02u.%01u", v_abs, abs((int16_t)(v * 10)) % 10 ); else sprintf( _buffer, "%03u ", v_abs );
lcd.print(_buffer); if(dc_flag) lcd.print("VDC "); else { lcd.print("VAC "); // calculate signal frequency in Hz uint32_t period_time = total_time/Periods; float freq = 1000000.0/period_time; sprintf( _buffer, "%02u.%02uHz", (uint16_t)freq % 100, (uint16_t)(freq * 100) % 100 ); lcd.print(_buffer); }
delay(500); // wait half a second
void ch_select(byte n) { switch(n) { case 0: digitalWrite(CH0, HIGH); digitalWrite(CH1, LOW); digitalWrite(CH2, LOW); digitalWrite(CH3, LOW); break; case 1: digitalWrite(CH0, LOW); digitalWrite(CH1, HIGH); digitalWrite(CH2, LOW); digitalWrite(CH3, LOW); break; case 2: digitalWrite(CH0, LOW); digitalWrite(CH1, LOW); digitalWrite(CH2, HIGH); digitalWrite(CH3, LOW); break; case 3: digitalWrite(CH0, LOW); digitalWrite(CH1, LOW); digitalWrite(CH2, LOW); digitalWrite(CH3, HIGH); } current_res = res_table[n]; }
// end of code.
jsotola
  • 1,554
oldbin
The input to the ADC is selected by the four least-significant bits of the “ADC Multiplexer Selection Register”, aka ADMUX. It is set to analog input 3 by this line of code:
ADMUX  = 0x03;
Change this line to ADMUX = 0; and the ADC will read pin A0.
Edgar Bonet
  • 45,094
  • 81
Your code is to hard to read, it is just a blob of characters on my screen but you have a pretty picture of the arduino. Change your code to use A0 instead of A3. Change your physical connection from A3 to A0 and you are all set. I miss read the code you posted.
It is a tricky circuit and he did all of the the registers directly, making it extremely hard to follow. I do not know the register set well enough to speak knowledgeable about what he is doing. The Optocouplers short out parts of the input divider network which he selects in his code. This is how he does the ranging. The optocouplers are drawn in reverse with the output on the left and the input on the right. Try this link to Nick Gammon's site: https://www.gammon.com.au/adc Also try this one: https://www.arduino.cc/en/Reference/PortManipulation
Gil
  • 1,863
