I am working on a project for my brothers and anyone else who is interested in playing some LED Pong. I was just stuck on the software part. I don't really know what to do. But, I have an idea: I want to use the map() function to make my life easier, however, I am not sure how to use the map function with the Dot Matrix. All help would be appreciated. All of the stuff came in this kit.
Here is the test code:
#include <LedControl.h>
int DIN = 2; int CS = 3; int CLK = 4;
const int playerOnePin = A0; const int playerTwoPin = A1;
int playerOneValue; int playerOneValue2; int playerTwoValue; int playerTwoValue2;
LedControl lc = LedControl(DIN, CLK, CS, 0);
lc.shutdown(0, false); //The MAX72XX is in power-saving mode on startup lc.setIntensity(0, 15); // Set the brightness to maximum value lc.clearDisplay(0); // and clear the display
pinMode(playerOnePin, INPUT); pinMode(playerTwoPin, INPUT);
byte a[8] = {0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; printByte(a);
void printByte(byte character []) {
int i = 0; for (i = 0; i < 8; i++) { lc.setRow(0, i, character[i]); } }
void readPot() {
playerOneValue = analogRead(A0);
playerOneValue2 = map(playerOneValue, 0, 1023, 0, 180); }
Here is the other code:
byte displayImage[8] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; // considering a 2d co-ordinate system with origin (0,0) at bottom left corner int ballX = 3; //X position int ballY = 7; //Y position - top int speedX = 0; // no X movement, can be -1, 0 or 1 int speedY = -1; // downward Y movement, can be -1, 0 or 1 int paddleX = 4; // X position of center of paddle - can be 1 to 6. Paddle width is 3 int score = 0;
void setup() { pinMode (A0, INPUT); pinMode (A1, INPUT); lc.shutdown(0, false); // Keep MAX72XX awake lc.setIntensity(0, 15); // Set the brightness to maximum value lc.clearDisplay(0); // and clear the display }
void loop() { // update ball position ballX = ballX + speedX; ballY = ballY + speedY;
// check for ball interaction with walls if (ballX == 0 || ballX == 7) { speedX = speedX * -1; // bouncing off walls in horizontal direction }
// bouncing off ceiling if (ballY == 7) { speedY = speedY * -1; // bouncing off the ceiling }
// bouncing off the paddle if (ballY == 0 && ballX >= (paddleX - 1) && ballX <= (paddleX + 1)) { speedY = speedY * -1; score++; // player earns a point }
// going past the paddle if (ballY == 0 && ballX < (paddleX - 1) && ballX > (paddleX + 1)) { // going past the paddle - player is out Serial.println(); Serial.print("Score: "); Serial.println(score); for (int i = 0; i < 8; i++) { displayImage[i] = 0x00; } displayImage[3] = 0xFF; displayImage[4] = 0xFF; // show a line renderByte(displayImage); while (1); // Freeze } // clearing the image variable for (int i = 0; i < 8; i++) { displayImage[i] = 0x00; }
// generating new image addPixel(ballX, ballY); // adding the ball position to image addPixel(paddleX - 1, 0); addPixel(paddleX, 0); addPixel(paddleX + 1, 0); // adding paddle position to image renderByte(displayImage); // show the generated image
// handling paddle control if (analogRead(A0) && paddleX > 0) { paddleX = paddleX - 1; // move paddle left }
if (analogRead(A1) && paddleX < 7) { paddleX = paddleX + 1; // move paddle right }
delay(200); }
void addPixel(int xVal, int yVal) { int newRowval = 2 ^ (7 - xVal); int rowVal = displayImage[7 - yVal]; displayImage[7 - yVal] = rowVal || newRowval; // inserting a 1 at the required pixel }
void renderByte(byte image []) { int i = 0; for (i = 0; i < 8; i++) { lc.setRow(0, i, image[i]); } }
Here is the picture of the wiring and the schematic:
This is the wiring picture
Wiring Pic
Wiring Pic
Wiring Pic
Schematic
Austin
  • 116
First figure out the min and max values that paddleX can have. I assume if the paddle is two dots wide then its min,max will be 0,6 Then figure out the min and max of your pot, typically 0,1023 for a a 10 bit adc. Now to map your pot value to paddleX value you'd use the command :
paddleX = map(analogRead(A0),0,1023,0,6);
here is the map documentation : https://www.arduino.cc/reference/en/language/functions/math/map/
tavis
  • 521
