I was creating a project where the following part of the code reads certain area of the display(which i screen shared from mobile)
import cv2 as cv
import numpy as np
from PIL import ImageGrab
import serial
arduinodata = serial.Serial('com5',9600)
def led_on(): arduinodata.write(b'1')
def led_off(): arduinodata.write(b'0') i=1
while True: screen = np.array(ImageGrab.grab(bbox=(0,0,1920,1080))) #define the screen resulation screen_res = 1920, 1080 scale_width = screen_res[0] / screen.shape[1] scale_height = screen_res[1] / screen.shape[0] scale = min(scale_width, scale_height) #resized window width and height window_width = int(screen.shape[1] * scale) window_height = int(screen.shape[0] * scale) #cv.namedWindow('Resized Window', cv.WINDOW_NORMAL) cv.resizeWindow('Resized Window', window_width, window_height) resized = screen.resize() health_bar = screen[262:268, 142:365]
health_grayed = cv.cvtColor(health_bar, cv.COLOR_BGR2GRAY)
count1 = cv.countNonZero(health_grayed)
if i==1: e =count1 i=0
if e>count1: led_on() e=count1
if e<count1:
e=count1
and whenever the value of the count1 variable decreases i want the Arduino led should be turned on
this was the arduino code
char serialData;
void setup() { // put your setup code here, to run once: pinMode(13,OUTPUT); digitalWrite(13,LOW); Serial.begin(9600);
void loop() // put your main code here, to run repeatedly: { if(Serial.available() >0) { digitalWrite(13,HIGH); delay(1000); digitalWrite(13,LOW);
But the led is turning on but does not turns off . I don't know why
can anyone please help me
Akash
This happens because you are not reading from Serial.
When you send data to the Arduino, it gets placed in the Serial buffer. Serial.available() then returns the number of bytes in the buffer. The bytes are removed from the buffer by Serial.read()ing them, which you don't do. Since you don't remove any bytes from the buffer, Serial.available() will always return a number greater than zero from the moment on, that the first byte arrives. After the delay you turn the LED off via digitalWrite(13,LOW);, but in the next loop iteration the if statement is again executed (as described above). This happens so fast, that you think the LED just stays on. In reality it gets turned of for maybe a few microseconds and then turned on again.
You are sending a single byte for the LED to react. So it would be the simplest solution to just read a single byte from the buffer inside of the if statement. The result can be discarded.
void loop()
    delay(1000);
    Serial.read();
The Serial.read() removes one byte from the buffer and returns it (so it gets discarded here). This way the LED blinks for every byte, that the Arduino receives over Serial.
Note: Depending on how fast you are sending the data you might want to make more clear, that you have individual bytes. With the above code the LED will light up for 3 seconds straight if you send 3 bytes in (relatively) fast succession (meaning consecutive bytes less than a second apart). To make it more clear, that you have 3 individual bytes, you can add a delay() call after turning the LED off. That gives you the chance to actually see it turning off.
chrisl
  • 16,622
