I am using an Arduino to control an AC Phase Control Circuit to control some lamps.
The problem is that the interrupts seem to break the code inside the loop().
This Code should just blink one lamp. But it doesnt!
What I found out so far:
The Led always has dim_level[22] so it seems like (at least the first) delay in the loop is skipped.
The strange thing:
When i add a statement that takes some time between the delays everything is working
For example
CH[0] = dim_level[0];
Serial.println("---------------------------------------------------------");
delay(500);
CH[0] = dim_level[22];
delay(500);
The not working code:
#include <TimerOne.h>
unsigned char channel_1 = 7; // Output to Opto Triac pin, channel 1
unsigned char channel_2 = 6; // Output to Opto Triac pin, channel 2
unsigned char channel_3 = 5; // Output to Opto Triac pin, channel 3
unsigned char channel_4 = 4; // Output to Opto Triac pin, channel 4
unsigned char CH1, CH2, CH3, CH4;
unsigned char i = 0;
unsigned char delay_time = 1; // delay ms or flashing SPEED
unsigned char clock_tick; // variable for Timer1
unsigned char CHANNEL_SELECT; // variable for channel select
unsigned char CH[] = {CH1, CH2, CH3, CH4};
unsigned char dim_level[] = {5, 8, 10, 12, 15, 18, 20, 25, 30, 35, 45, 50, 55, 60, 65, 70, 75, 80, 82, 85, 88, 92, 95}; // don't use this massive for 60Hz
// create new massive for 60Hz
Serial.begin(2000000);
pinMode(channel_1, OUTPUT);// Set AC Load pin as output
pinMode(channel_2, OUTPUT);// Set AC Load pin as output
pinMode(channel_3, OUTPUT);// Set AC Load pin as output
pinMode(channel_4, OUTPUT);// Set AC Load pin as output
attachInterrupt(1, zero_crosss_int, RISING);
Timer1.initialize(100); // set a timer of length 100 microseconds for 50Hz or 83 microseconds for 60Hz;
Timer1.attachInterrupt( timerIsr ); // attach the service routine here
void timerIsr()
clock_tick++;
if (CH[0] == clock_tick)
digitalWrite(channel_1, HIGH); // triac firing
delayMicroseconds(10); // triac On propogation delay (for 60Hz use 8.33)
digitalWrite(channel_1, LOW); // triac Off
if (CH[1] == clock_tick)
digitalWrite(channel_2, HIGH); // triac firing
digitalWrite(channel_2, LOW); // triac Off
if (CH[2] == clock_tick)
digitalWrite(channel_3, HIGH); // triac firing
digitalWrite(channel_3, LOW); // triac Off
if (CH[3] == clock_tick)
digitalWrite(channel_4, HIGH); // triac firing
digitalWrite(channel_4, LOW); // triac Off
void zero_crosss_int() // function to be fired at the zero crossing to dim the light
clock_tick = 0;
delay(500);
delay(500);
Im new to arduino maybeIi miss some concepts but I read that interupts should not break delays outside interrupt
