I think the issue is within the library because I have try to implement this code according to the tutorial that I found in YouTube Youtube. The discussion of this tutorial is the first they implement the node js server for listening to specific event from socket io, second part they build a simple iOS application using swift to control an RGB light on the ESP8266 and the last part they make ESP8266 to listen to the event that have payload as RGB values. However, in my implementation, I use angular web application to control ON-OFF light on the Arduino but the problem when I try to listen to event that on and off, my ESP8266 don't connect to my server and print all of that message on the serial.
Here is the code for my ESP8266 to connect to my node server.
#include <SocketIoClient.h> #include<ESP8266WiFi.h> #include<Arduino.h> #define USER_SERIAL Serial
SocketIoClient socket; const char* ssid = "bunvath_guest"; const char* pass = "*************"; void setup() { USER_SERIAL.begin(115200); searchWifi(); initWiFi(); socket.on("message", handleMessage); socket.on("light_on",handleMessage); socket.emit("message","hello from esp"); socket.begin("192.168.0.102",3000); }
void loop() { socket.loop(); } void handleMessage(const char* message, size_t length){ USER_SERIAL.println(message); }
void initWiFi(){ WiFi.mode(WIFI_STA); WiFi.hostname("ESP-host"); WiFi.setPhyMode(WIFI_PHY_MODE_11G); WiFi.enableInsecureWEP(true); WiFi.begin(ssid,pass); while(WiFi.status() != WL_CONNECTED){ USER_SERIAL.print("."); delay(1000); } USER_SERIAL.print(""); USER_SERIAL.println("WiFi connected"); USER_SERIAL.print("IP Address: "); USER_SERIAL.println(WiFi.localIP()); WiFi.setAutoReconnect(true); WiFi.persistent(true);
} void searchWifi(){ int numberOfNetwork = WiFi.scanNetworks(); USER_SERIAL.println("-----"); for ( int i = 0; i< numberOfNetwork;i++){ USER_SERIAL.print("Network name: "); USER_SERIAL.println(WiFi.SSID(i)); USER_SERIAL.print("Signal Strength: "); USER_SERIAL.println(WiFi.RSSI(i)); USER_SERIAL.println("-------------"); } }
Here is my node server code for receiving all connection from client and print the client id when new client is connecting. Moreover, this node server will listen to all the event that client emit and broadcast to other client.
var port = process.env.PORT||3000
const http = require('http')
const app = require('./app')
const cors = require('cors'); let message = '' const server = http.createServer(app) const io = require('socket.io')(server,{cors:{ origin:'http://localhost:4200', credentials: true }} )
server.listen(port,()=>{ console.log("server run on ", port) })
io.on("connection",(socket)=>{ console.log(socket.id) socket.on('message', data =>{ // console.log(data) socket.broadcast.emit('message',data) }) socket.on('open_light',data=>{ socket.broadcast.emit('open_light',data) console.log(data) })
Here is the message that I got from serial monitor, I feel like my Arduino has already connected to my server but it keep getting reconnect. Moreover, in my sever I did not see any new client connect to server so I am really what going on with this. Plus, I am sure that my node server is working perfectly fine because I have implement angular web application to emit event, and I saw that event printing in server.
12:57:13.083 -> Network name: Meas Nakry
12:57:13.083 -> Signal Strength: -85
12:57:13.083 -> -------------
12:57:13.083 -> Network name: bunvath_guest
12:57:13.083 -> Signal Strength: -57
12:57:13.083 -> Network name: BLaNKxD
12:57:13.083 -> Signal Strength: -89
12:57:13.121 -> -------------
12:57:13.121 -> Network name: Tuy vanny1
12:57:13.121 -> Signal Strength: -85
12:57:13.121 -> ....WiFi connected
12:57:17.165 -> IP Address: 192.168.0.100
12:57:17.165 -> [SIoC] add packet 42["message",hello from esp]
12:57:17.269 -> [SIoC] Disconnected!
12:57:17.269 -> [SIoC] event disconnected not found. 2 events available
12:57:17.787 -> [SIoC] Disconnected!
12:57:17.787 -> [SIoC] event disconnected not found. 2 events available
12:57:18.376 -> [SIoC] Disconnected!
12:57:18.376 -> [SIoC] event disconnected not found. 2 events available
12:57:18.992 -> [SIoC] Disconnected!
12:57:18.992 -> [SIoC] event disconnected not found. 2 events available
12:57:19.633 -> [SIoC] Disconnected!
12:57:19.633 -> [SIoC] event disconnected not found. 2 events available
12:57:20.217 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:20.217 -> [SIoC] packet "42["message",hello from esp]" emitted
12:57:20.251 -> [SIoC] Disconnected!
12:57:20.251 -> [SIoC] event disconnected not found. 2 events available
12:57:20.771 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:20.771 -> [SIoC] Disconnected!
12:57:20.771 -> [SIoC] event disconnected not found. 2 events available
12:57:21.435 -> [SIoC] Disconnected!
12:57:21.435 -> [SIoC] event disconnected not found. 2 events available
12:57:22.044 -> [SIoC] Disconnected!
12:57:22.044 -> [SIoC] event disconnected not found. 2 events available
12:57:22.596 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:22.596 -> [SIoC] Disconnected!
12:57:22.596 -> [SIoC] event disconnected not found. 2 events available
12:57:23.178 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:23.178 -> [SIoC] Disconnected!
12:57:23.178 -> [SIoC] event disconnected not found. 2 events available
12:57:23.798 -> [SIoC] Disconnected!
12:57:23.798 -> [SIoC] event disconnected not found. 2 events available
12:57:24.403 -> [SIoC] Disconnected!
12:57:24.403 -> [SIoC] event disconnected not found. 2 events available
12:57:24.945 -> [SIoC] Disconnected!
12:57:24.945 -> [SIoC] event disconnected not found. 2 events available
12:57:25.533 -> [SIoC] Disconnected!
12:57:25.533 -> [SIoC] event disconnected not found. 2 events available
12:57:26.201 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:26.201 -> [SIoC] Disconnected!
12:57:26.201 -> [SIoC] event disconnected not found. 2 events available
12:57:26.792 -> [SIoC] Disconnected!
12:57:26.792 -> [SIoC] event disconnected not found. 2 events available
12:57:27.380 -> [SIoC] Disconnected!
12:57:27.380 -> [SIoC] event disconnected not found. 2 events available
12:57:27.894 -> [SIoC] Disconnected!
12:57:27.894 -> [SIoC] event disconnected not found. 2 events available
12:57:28.711 -> [SIoC] Disconnected!
12:57:28.711 -> [SIoC] event disconnected not found. 2 events available
12:57:29.426 -> [SIoC] Disconnected!
12:57:29.426 -> [SIoC] event disconnected not found. 2 events available
12:57:30.131 -> [SIoC] Disconnected!
12:57:30.131 -> [SIoC] event disconnected not found. 2 events available
12:57:30.655 -> [SIoC] Disconnected!
12:57:30.655 -> [SIoC] event disconnected not found. 2 events available
12:57:31.254 -> [SIoC] Disconnected!
12:57:31.254 -> [SIoC] event disconnected not found. 2 events available
12:57:31.787 -> [SIoC] Disconnected!
12:57:31.787 -> [SIoC] event disconnected not found. 2 events available
12:57:32.375 -> [SIoC] Disconnected!
12:57:32.375 -> [SIoC] event disconnected not found. 2 events available
12:57:33.171 -> [SIoC] Disconnected!
12:57:33.171 -> [SIoC] event disconnected not found. 2 events available
12:57:33.731 -> [SIoC] Disconnected!
12:57:33.731 -> [SIoC] event disconnected not found. 2 events available
12:57:34.435 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:34.435 -> [SIoC] Disconnected!
12:57:34.435 -> [SIoC] event disconnected not found. 2 events available
12:57:34.978 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:34.978 -> [SIoC] Disconnected!
12:57:34.978 -> [SIoC] event disconnected not found. 2 events available
12:57:35.581 -> [SIoC] Disconnected!
12:57:35.581 -> [SIoC] event disconnected not found. 2 events available
12:57:36.180 -> [SIoC] Disconnected!
12:57:36.180 -> [SIoC] event disconnected not found. 2 events available
Hope anyone can find what is the issue in these codes, I am really frustrated about this for 3 days already.
Ly Bunvath
I think you need to allow all origins, at least to begin with. At the moment, only connections coming from the machine running node can access the sever.
Removing credentials as a next step, which I can't see being used, may also move your testing along.
    origin:'*:*',
    credentials: true
voidPointer
  • 305
