I'm successfully sending a GET request (in the setup function, to load certificates,) but my POST request fails with a bunch of AT errors. I suspect this has to do with the way I'm formatting the POST. Any ideas would be appreciated.
Code follows:
// MKRGSM - Version: 1.5.0
#include <MKRGSM.h>
#include <ArduinoJson.h>
#include <Arduino_MKRGPS.h>
const char PINNUMBER[] = "";
// APN data
const char GPRS_APN[] = SECRET_GPRS_APN;
const char GPRS_LOGIN[] = "";
const char GPRS_PASSWORD[] = "";
DynamicJsonDocument doc(1024);
// initialize the library instance
GSMSSLClient client;
GPRS gprs;
GSM gsmAccess(true);
// Specify IP address or hostname
char server[] = "webhook.site";
char path[] = "/ce480c43-95a8-4f1e-b996-bc02f6d1adaa";
int port = 443;
// initialize serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// If you are using the MKR GPS as shield, change the next line to pass
// the GPS_MODE_SHIELD parameter to the GPS.begin(...)
delay(200);
if (!GPS.begin()) {
Serial.println("Failed to initialize GPS!");
while (1);
Serial.println("Starting Arduino GSM ping.");
// connection state
bool connected = false;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (!connected)
if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &&
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY))
connected = true;
else
Serial.println("Not connected");
delay(1000);
Serial.println("connecting...");
// if you get a connection, report back via serial:
// Use this to load Root Certs the first time
if (client.connect(server, port))
// Use this to not load Root Certs anymore as done last time and stored in modem's flash
// if (client.connect(server, port, false))
Serial.println("connected");
// Make a HTTP request:
client.print("GET ");
client.print(path);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(server);
client.println("Connection: close");
client.println();
else
// if you didn't get a connection to the server:
Serial.println("connection failed");
...GPS stuff happens here
// print GPS values
Serial.println();
Serial.print("Location: ");
Serial.print(latitude, 7);
Serial.print(", ");
Serial.println(longitude, 7);
Serial.print("Altitude: ");
Serial.print(altitude);
Serial.println("m");
Serial.print("Number of satellites: ");
Serial.println(satellites);
doc["latitude"] = latitude;
doc["longitude"] = longitude;
doc["altitude"] = altitude;
String location;
serializeJson(doc, location);
Serial.print("Location string: ");
Serial.println(location);
Serial.println();
Serial.println("Starting Arduino web client.");
// connection state
if (client.available()) {
Serial.println("Sending location");
client.print("POST ");
client.print(path);
delay(5);
client.println("Content-Type: application/json;");
delay(5);
client.print("Content-Length: ");
client.println(location.length());
delay(5);
delay(5);
client.println();
delay(5);
client.println(location);
Serial.print("Successfully sent location");
if (!client.available() && !client.connected()) {
Serial.println();
Serial.println("disconnecting.");
client.stop();
} else {
Here's what the output looks like:
Location: 32.1208382, 35.2468376 Altitude: 640.40m Number of satellites: 5 Location string: {"latitude":32.12084,"longitude":35.24684,"altitude":640.4}
Starting Arduino web client. Sending location AT+USOWR=0,13,"504F53542068747470733A2F2F"
ERROR AT+USOWR=0,37,"2F63653438306334332D393561382D346631652D623939362D626330326636643161646161"
ERROR AT+USOWR=0,9,"20485454502F312E31"
ERROR AT+USOWR=0,2,"0D0A"
ERROR AT+USOWR=0,31,"436F6E74656E742D547970653A206170706C69636174696F6E2F6A736F6E3B"
ERROR AT+USOWR=0,16,"436F6E74656E742D4C656E6774683A20"
ERROR AT+USOWR=0,2,"3539"
ERROR AT+USOWR=0,6,"486F73743A20"
ERROR AT+USOWR=0,12,"776562686F6F6B2E73697465"
ERROR AT+USOWR=0,17,"436F6E6E656374696F6E3A20636C6F7365"
ERROR AT+USOWR=0,59,"7B226C61746974756465223A33322E31323038342C226C6F6E676974756465223A33352E32343638342C22616C746974756465223A3634302E347D"
ERROR
I could send the data as parameters in the GET query, but that's ugly.
