My NodeMCU wont connect to Blynk with my code but works fine with example code and same auth token and WiFi info. Cant figure out why its not working. Must be something in my code interfering with it (Or something stupid I'm missing). Any ideas? Thanks!
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "AUTH";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "SSID";
char pass[] = "PASSWD";
const int analogPin = A0;
const int muxA = 9;// MUX pin A
const int muxB = 10;//MUX pin B
const int muxC = 16;//MUX pin C
const int outputPin0 = 4;// output pin 0
const int outputPin1 = 5;// output pin 1
const int outputPin2 = 12;//Output pin 2
const int outputPin3 = 13;//output pin 3
const int outputPin4 = 14;//output pin 4
int startWatering0 = 1023;//start watering value 0
int startWatering1 = 1023;//start watering value 1
int startWatering2 = 1023;//start watering value 2
int startWatering3 = 1023;//start watering value 3
int startWatering4 = 1023;//start watering value 4
int currentMoisture0 = 0;//current moisture value 0
int currentMoisture1 = 0;//current moisture value 1
int currentMoisture2 = 0;//current moisture value 2
int currentMoisture3 = 0;//current mousture value 3
int currentMoisture4 = 0;//current moisture value 4
int wateringTime0 = 0;//watering time 0
int wateringTime1 = 0;//watering time 1
int wateringTime2 = 0;//watering time 2
int wateringTime3 = 0;//watering time 3
int wateringTime4 = 0;//watering time 4
bool isWatering0 = false;//is 0 currently watering
bool isWatering1 = false;//is 1 currently watering
bool isWatering2 = false;//is 2 currently watering
bool isWatering3 = false;//is 3 currently watering
bool isWatering4 = false;//is 4 currently watering
long wateringStart0 = 0;//watering 0 start value
long wateringStart1 = 0;//watering 1 start value
long wateringStart2 = 0;//watering 2 start value
long wateringStart3 = 0;//watering 3 start value
long wateringStart4 = 0;//watering 4 start value
BlynkTimer timer;
void setup()
//initialize outputs
pinMode(muxA, OUTPUT);
pinMode(muxB, OUTPUT);
pinMode(muxC, OUTPUT);
pinMode(outputPin0, OUTPUT);
pinMode(outputPin1, OUTPUT);
pinMode(outputPin2, OUTPUT);
pinMode(outputPin3, OUTPUT);
pinMode(outputPin4, OUTPUT);
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
timer.setInterval(1000L, checkSensors);
void checkSensors()
//check sensors here
setMux0();
currentMoisture0 = analogRead(analogPin);
setMux1();
currentMoisture1 = analogRead(analogPin);
setMux2();
currentMoisture2 = analogRead(analogPin);
setMux3();
currentMoisture3 = analogRead(analogPin);
setMux4();
currentMoisture4 = analogRead(analogPin);
setMux5();
setMux6();
setMux7();
Blynk.virtualWrite(V11, currentMoisture0);
Blynk.virtualWrite(V12, currentMoisture1);
Blynk.virtualWrite(V13, currentMoisture2);
Blynk.virtualWrite(V14, currentMoisture3);
Blynk.virtualWrite(V15, currentMoisture4);
//starts watering if soil is drier than set value, and if it is not already watering
if(currentMoisture0 >= startWatering0 && isWatering0 == false)
isWatering0 = true;
digitalWrite(outputPin0, HIGH);
wateringStart0 = millis();
if(currentMoisture1 >= startWatering1 && isWatering1 == false)
isWatering1 = true;
digitalWrite(outputPin1, HIGH);
wateringStart1 = millis();
if(currentMoisture2 >= startWatering2 && isWatering3 == false)
isWatering2 = true;
digitalWrite(outputPin2, HIGH);
wateringStart2 = millis();
if(currentMoisture3 >= startWatering3 && isWatering3 == false)
isWatering3 = true;
digitalWrite(outputPin3, HIGH);
wateringStart3 = millis();
if(currentMoisture4 >= startWatering4 && isWatering4 == false)
isWatering4 = true;
digitalWrite(outputPin4, HIGH);
wateringStart4 = millis();
//stops watering if it is currently watering, and it has been watering for longer than the set time
if(millis() >= wateringStart0 + (wateringTime0 * 60000 ) && isWatering0 == true)
digitalWrite(outputPin0, LOW);
if(millis() >= wateringStart1 + (wateringTime1 * 60000 ) && isWatering1 == true)
digitalWrite(outputPin1, LOW);
if(millis() >= wateringStart2 + (wateringTime2 * 60000 ) && isWatering2 == true)
digitalWrite(outputPin2, LOW);
if(millis() >= wateringStart3 + (wateringTime3 * 60000 ) && isWatering3 == true)
digitalWrite(outputPin3, LOW);
if(millis() >= wateringStart4 + (wateringTime4 * 60000 ) && isWatering4 == true)
digitalWrite(outputPin4, LOW);
void setMux0()//sets mux to pin 0
digitalWrite(muxA, LOW);
digitalWrite(muxB, LOW);
digitalWrite(muxC, LOW);
void setMux1()//sets mux to pin 1
digitalWrite(muxA, HIGH);
void setMux2()//sets mux to pin 2
digitalWrite(muxB, HIGH);
void setMux3()//sets mux to pin 3
void setMux4()//sets mux to pin 4
digitalWrite(muxC, HIGH);
void setMux5()//sets mux to pin 5
void setMux6()//sets mux to pin 6
void setMux7()//sets mux to pin 7
//sets values when they are changed in app
//start watering values
BLYNK_WRITE(V1)
int startWatering0 = param.asInt();
BLYNK_WRITE(V2)
int startWatering1 = param.asInt();
BLYNK_WRITE(V3)
int startWatering2 = param.asInt();
BLYNK_WRITE(V4)
int startWatering3 = param.asInt();
BLYNK_WRITE(V5)
int startWatering4 = param.asInt();
//watering time values
BLYNK_WRITE(V6)
int wateringTime0 = param.asInt();
BLYNK_WRITE(V7)
int wateringTime1 = param.asInt();
BLYNK_WRITE(V8)
int wateringTime2 = param.asInt();
BLYNK_WRITE(V9)
int wateringTime3 = param.asInt();
BLYNK_WRITE(V10)
int wateringTime4 = param.asInt();
void loop()
Blynk.run();
timer.run();
