I am working on a project with a claw machine. I am working on this chip (CD4067BE which is equivalent to the CD74HC4067) and I was wondering: can I read more than one button with the CD4067? I tried the following code, and it works great, but when I want to push two buttons, it will not read both of them as zero. Why am I using a chip with the buttons? It was to reduce I/O pins on my PCB for the claw machine. Yes, I could use a matrix, but I want control over my components, whether to turn it on or off. Also, the CD4067 includes all my buttons. I have thirteen buttons. (13 buttons). By the way, this chip is a multiplexer/demultiplexer. I am using this chip as a multiplexer. Oh, and also, I have an Arduino Mega 2560 rev3. I have followed the instructions of this question, but this doesn't answer if the chip can read more than button at one time. Thanks,
Austin
//Mux control pins
int s0 = 5;
int s1 = 4;
int s2 = 3;
int s3 = 2;
//Mux in "SIG" pin
int SIG_pin = 6;
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
pinMode(SIG_pin, INPUT_PULLUP);
Serial.begin(9600);
//Loop through and read all 16 values
for (int i = 0; i < 16; i ++) {
Serial.print("Value at channel ");
Serial.print(i);
Serial.print("is : ");
Serial.println(readMux(i));
delay(1000);
int readMux(int channel) {
int controlPin[] = {s0, s1, s2, s3};
int muxChannel[16][4] = { {0, 0, 0, 0},
{1, 0, 0, 0},
{0, 1, 0, 0},
{1, 1, 0, 0},
{0, 0, 1, 0},
{1, 0, 1, 0},
{0, 1, 1, 0},
{1, 1, 1, 0},
{0, 0, 0, 1},
{1, 0, 0, 1},
{0, 1, 0, 1},
{1, 1, 0, 1},
{0, 0, 1, 1},
{1, 0, 1, 1},
{0, 1, 1, 1},
{1, 1, 1, 1}
//loop through the 4 sig
for (int i = 0; i < 4; i ++) {
digitalWrite(controlPin[i], muxChannel[channel][i]);
//read the value at the SIG pin
int val = digitalRead(SIG_pin); //return the value
return val;
