What I'd like to do is have some kind of compact (and preferably inexpensive) Arduino-compatible device emulate a USB hub, and simulates plugging in a USB keyboard, pressing a key, then simulates unplugging the keyboard.
The goal here being a USB-connected device with media-control buttons for an Android device, but since plugging in a device that acts as a keyboard disables the on-screen keyboard, the idea is that it only acts like a keyboard when a button is pressed, but keeps a connection going while it's plugged in.
Is this at all possible with any Arduino-compatible device, do I need to look for a different embedded architecture, or do I need a particular kind of USB converter chip?
Raceimaztion
  • 151
Since an Arduino is "just" a microcontroller with some specific bootloader and commonly programmed via the Arduino IDE, you can also program it like any other microcontroller.
There are several projects offering USB functionality as a library, in the Arduino world or outside of it. Use your favorite web search engine to find them. With such a library you should be able to tackle your task.
However, this is not a beginner's task. Please note that you might need to learn a lot.
I'd say that even the simplest AVR based Arduino should suffice.
the busybee
  • 2,408
